I'm actually going to post a solution to this problem, since I figured it out today and I want to share the solution with others who are pulling their hair out — like I was.
Comments:
Apr 28, 2009
- Okay, here's what I figured out today. The yellow plastic tape that runs across the top of the Epson ink cartridges actually serves a purpose — it lets air in there when printing. No air, no ink output, which means no printing. Here's the thing, I did pull the tape off, but a clear layer of the tape, like cellophane thick, stayed on there and kept it air tight. So after I figured it out I cut the clear layer, and made sure air could get in there through the channel molded into the plastic. No a seeming dead ink cartridge works fine. How that helps someone. I've never seen this tip anywhere online, and I looked all over.
And if you're having trouble with a suddenly, seemingly dead Epson 740 that has all the lights blinking, I found a solution for that today too. Look for my other posting. Scott
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using...
(More)
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using is still working properly. it has a 110 input v.
