Question about iRiver H320 MP3 Player
Iriver h320 battery problems
First I charge the battery full then if I unplug it and turn it off, the battery keeps running. so its off for 15 hours then wont turn on due to low battery....NOw I charge it full and turn it on and it only works for 15 min and turns it self off and says the battery is dead
  • Anonymous Mar 09, 2009
    the battery discharges weather the unit is on or off. the battery has already been replaced so it's not the battery. this started after a charger failed and the output went too high.
Your battery is broken you must buy new battery (very good battery is 2200 mAh because battery install in your iriver is 1350 mAh)
Posted on Oct 14, 2007
SOURCE:
I just replaced my H320 iRiver battery last night. When I plug it in, it says it's charging. I let it charge overnight and it's still saying it's charging. When I unplug it and try to turn it on,...
Probably you installed wrong. Depending on the battery manufacturer, the end contacts must be swithced in order for the battery to work. Read about it in the Misticriver forums. Good luck!
Oct 28, 2009 | iRiver H320 MP3 Player
H300 battery after being charged lasts about 15 minutes tops
buy a battery kit from the site underneath your question and install it yourself.I did this-cost $29 now my iriver h320 has anew life and is better than ever!
Mar 29, 2009 | iRiver H320 MP3 Player
Iriver H320 will not turn on
After 3 years constant use my iriver H320 would not charge.I bought a new battery kit online and fitted it myself.Now its like having a new iriver!
p.s. not bad for a technophobe eh!
Regards Tezra.
Mar 25, 2009 | iRiver H320 MP3 Player
Iriver H320 GIVES ME PROBLEMS
can i suggest that you download rockbox software (it does everything iriver firmware but is not a strain on the battery life) www.rockbox.org for h320.....................and or you can buy a new battery, here an ebay link http://cgi.ebay.com/NEW-High-Capacity-1700MAH-Battery-iRiver-H320-H110-FSH_W0QQitemZ390057094924QQihZ026QQcategoryZ20336QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
start over as new
Sep 17, 2008 | iRiver H320 MP3 Player
IRIVER H300
Sounds like a battery problem. You'll need to replace it.If you have the expertise there are instructions on the net.
Aug 17, 2008 | iRiver H320 MP3 Player
MY IRIVER GIVE ME HEADACHE
Sounds like you'll need a new battery.
Aug 09, 2008 | iRiver H320 MP3 Player
IRiver H320 will not charge
did you turn off your USB so that the AC adapter can get through to recharge your battery.
Apr 02, 2008 | iRiver H320 MP3 Player
H320 keeps switching off. Battery is fully charged.
Re chargables are not forever, and it could be the culprit here. Also if it has a power save more it may decide you are not using the player and not sensing your browsing. Maximum life span of a normal use rechargable is 2 years or the hours marked on the packaging it came in, like 3000. Do the math. High energy drain devices also wear out their batteries faster if the backlight and keys are in constant use, turn the brightness down and run off a list of your tunes from you computer program and look at that.
Sep 24, 2007 | iRiver H320 MP3 Player
IRiver H320 is completely dead
Hi, you can get a step by step video tutorial on how to change the battery here.. http://www.videojug.com/film/how-to-replace-the-battery-in-your-iriver-h320-or-h340 all the best John
Mar 04, 2007 | iRiver H320 MP3 Player
IRiver H320 won't turn on
Hi Andy- I have the same problem. Spoke to IRvier America & was told that they have no repair service for anything out of warranty- so we're on our own. Was also told that there are third party repair companies that can be found online. Myabe between the 2 of us we can find a solution. Care to keep in touch? Terese
Dec 27, 2006 | iRiver H320 MP3 Player
iRiver H320 MP3 Player Logo
239 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
