Question about GE GSS25SGMBS Side by Side Refrigerator
Ge refrigerator model TFH22JW problem
The refrigerator section is not cooling properly. The side by side freezer is working properly.
  • Anonymous Mar 12, 2014
    THE SMALL FLIP OUT SECTION ON THE LEFT HAND SIDE OF THE DOOR HAS SLIPPED OUT OF THE CATCH AND THE DOOR WON'T OPEN PROPERLY. MODEL # RF260BEAEWW
How do I fix this problem..What do I need to do to change this out and how do I know for sure if this is it?
Posted on Nov 18, 2008
  • 114 Answers
You most likely have an automatic defrost problem. When one of more of the defrost components fails, frost accumulates behind the freezer wall and restricts airflow to the fresh food side. You will still generate cold into the freezer section but will have virtually no cold to fresh food side. If it is a few years old it is most likely the defrost heater which is defective. Replace the defrost thermostat (bi-metal) as well.
Posted on Oct 02, 2007
SOURCE:
Side by side GE TFT28PFBBWW freezer ok, refrigerator side cools interminently, most of the times does not cool at all
The problem is defrost.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
Freezer gets cold but rerfrigerator does not on my side by side model TFX20JEX
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 25, 2010 | GE Refrigerators
My side by side refrigerator is not cooling in the top half of the refrigerator section. The freezer is working properly and the bottom drawers in the refrigerator side are cooling properly. It is 2004 GE...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 18, 2010 | GE GSH25JSRSS Stainless Steel Side by Side...
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
Freezer problem
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Oct 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
560 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
