Question about HP OfficeJet 6210 All-In-One InkJet Printer
Error message :0x8824ac6a1:a524hC04LHB1n|. previous error message :0xb90020e1165:hw_interrupt. previous error msg : 0x84049c751. previously would not print anything. now it will print test print and alignment page. tries to continue printing but stops. will not fax or copy. help!
  • ravinn
    ravinn Oct 31, 2013
    error msgs are displayed on my hp 6210 printer, not on computer screen. does anyone have access to what the error codes mean without my having to call hp and pay them? printer lights are flashing like crazy. never seen it do this before. have gone thru the trouble shooting software. thanks!!
    New Friend:
Error massage scan gear error 21,40,21
printer name mp280 all in one
Posted on Oct 31, 2013
Testimonial: "error msgs are on the printer not the pc. hp officejet 6210 allinone inkjet."
SOURCE:
  • 624 Answers
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
  • 108 Answers
SOURCE: HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Posted on Feb 12, 2008
SOURCE: hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Posted on Jun 01, 2008
jaznet
  • 75 Answers
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Posted on Sep 14, 2008
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
Error Code: 0146 Msg: Error code 2000-0146 Msg : Unit 1:DST log contains previous error (s) please help me, how i can solve this problem
I am assuming that this is a problem on a dell computer? If so that error message is an indicator that your hard drive is probably going bad and you need to back up you data and get a new one ASAP. I believe that laptop takes 2.5" 9.5 mm sata laptop drives
May 17, 2011 | Computers & Internet
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
HP OfficeJet 6210 All-In-One InkJet Printer Logo
112 people viewed this question
Clive
Clive
Thomas F. Schneider
