Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire ATFB6000ES1 won't do anything...
There's another posting just like on here, but having spoken with a tech, he said to check a different part. Here's the issue: the machine wouldn't start when I tried to run a load of clothes. The lights are on, put the display flashes between "PAU" and "50." When I press any of the buttons, I get 3 beeps and an error. I have tried to pull the error code with the Start/Cancel buttons, but it doesn't work. A tech suggested that it could be the door/lid switch has become disconnected. Seems like that could be related as the machine responds the same way whether or not the door is open. I don't know how to check the door/lid switch. Am I barking up the wrong tree? Is it really the control board like it was for the other person? What's involved in replacing the control board and/or the door/lid switch? Thanks!
  • 1 more comment
  • gottspd Oct 02, 2007
    Thanks for the reply, but I've tried no fewer than 50 times to get the error code with the start/cancel button press. All that happens is that I get "ERR" on the display and 3 beeps, which is the same result I get when I press any key. Any suggestions?
  • gottspd Oct 03, 2007
    Believe me, I understand the process. I've tried this dozens of times and it doesn't work.
    Believe me, I understand the process. It just doesn't work. It just says "ERR" and beeps 3 times.
My Frigidaire was doing the same thing. I tried holding the Start/Pause buttons, but I didn't get an error code or anything.
So just for the heck of it my husband unplugged it for 5 seconds, then he held down the Option and the Select buttons together and then only the spin light was on so I pushed start and it started. I guess it was stuck on spin.
Good Luck !
Posted on Nov 16, 2007
  • 447 Answers
The code can be pulled you really should figure out what is it trying to tell me before you go replacing its brain. The new one 50% of the time will throw the same code using this type of shot in the dark diagnostics.
Posted on Oct 02, 2007
  • joey  shearer
    joey shearer Oct 02, 2007
    Here is the Routine
    The electronic control has self diagnostics error codes built in that cover most products failures.
    READING ERROR CODES:
    1. Wake the washer by pressing any button.
    2. Wait 5 seconds.
    3. Press and HOLD the Start/Pause and Cancel
    buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock,Wash, Rinse, and Final Spin indicator lights will flash
    Is everything displaying as it should??
    what is the display??
  • joey  shearer
    joey shearer Oct 03, 2007
    are you waiting the 5 secs??
Atfb6000es1 frigidaire washer beeps ramdomly
Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATFB6000ES1, is beeping randomly. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if you are hearing your washer randomly beeping. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
My frigidaire atfb6000se1 is making a grinding noise pretty much the whole time its on...
Good Morning Friend,
I understand that you are hearing a constant grinding sound while your Frigidaire washer, model# ATFB6000ES1, is running. There could be a possibility that your washer is overloaded. Do not overload washer. Stop washer and reduce load. If this does help with the grinding sound, I suggest resetting your appliance. You can do this by either, unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. . I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire ATF6000ES Front Load Washer
Frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity atfb6000es1 e47
Remove the door lockassembly and measure the resistance of the PTC. Shorted or open, defective doorlock assembly. Reads around 1500 ohms, defective Main Control Board.
Aug 03, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
My Frigidaire ATFB6000ES1 stops during wash cycle with a ''dr'' code that my door is open even though it is closed
the door lock mechanism is faulty and needs to be replaced. very rare occassion you have a bad control board
Sep 21, 2009 | Frigidaire Washing Machines
Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
May 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
May 20, 2008 post
Tech support for this model has advised us that the motherboard is bad. This apparently has happened to a number of people and in my opinion there should be a recall. Has anyone else spoken to iLO Tech Support regarding this?
May 28, 2008 | iLO 2600 Television
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
Oct 24, 2006 | Lanier 5222/27 Laser Printer
Frigidaire ATF6000ES Front Load Washer Logo
481 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
