FixYa.com
Tags:
Scanners
Generic problem for all Scanners
How to add more pages while scanning with Umax...
posted by tariqcrown on Oct 01, 2007
Is is to possible to insert / add-on more pages, while doing scanning with Umax Astra 5600
Thanks & regards
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 03, 2007
Thanks for Trying (70)
MUKHTAR
Rank:Wiz Wiz
Rating: 77%, 455 votes
no it is not possible bocz in this tyep model scanner dont have adf (automatic document feeder) it is bettre if you want to scan multiple pager then go for high end scanner model
bye
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 04, 2007
Not Rated (0)
Vishal51
Rank:Wiz Wiz
Rating: 80%, 86 votes
Scan a page, after that send it/save it, now does it display the option to scan another page or to finish it. If it does, select scan another page and proceed. If not the s/w supplied with the scanner does not support this function.
In any case you can use pdf creating softwares like Adobe acrobat (not acrobat reader) to achieve the same result. These softwares support scanning function as as well as you can subsequently insert/ remove pages from a pdf file.
This Problem Also Relates To: HP ScanJet 2400 Flatbed Scanner HP 5590 ScanJet Flatbed Scanner with ADF (Free Shipping) HP 9200c Flatbed Scanner Panasonic Mdwd with Expansion Base Finger Print Scanner & Mag Stripe Reader Acer AcerScan 310P Flatbed Scanner Acer AcerScan 610P Flatbed Scanner Acer AcerScan Prisa 340P Flatbed Scanner
Can you Help with these Scanners problems?
HP ScanJet 3970 Flatbed Scanner
Scaner not found
My Mac 10.3.9 do not find the... Answer This...
Scanners
Inability to transfer slides...
I have scanned my slides using... Answer This...
Umax Astra 6700 Flatbed Scanner
Sug: Window Vista driver of...
Dear Sir I have a umax astra... Answer This...
Canon CanoScan D646U Flatbed Scanner
scaner driver
i have lost my cd of driver i... Answer This...
Acer ScanPrisa 640U Flatbed Scanner
acerscan 620U upgrade to Vista
Hi, I'm trying to get my... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
