Question about Sony VPL PX40 Multimedia Projector
Bulb Reset issue
When a new bulb was installed i could not get the unit to reset by using the manuals sequence of "reset, <,>, enter" any ideas on a fix? any other ways to reset? let me know!? thanks
  • bz6039 Dec 17, 2007
    Thanks! I guess it was as simple as being in the right mode. I really do appreciate it.
I had the same problem and called Sony, they just said to keep trying what the manual says to do, but make sure the unit is in standby mode. I tried in powered mode and in standby mode many times and it did not work. Then I tried again the next day when the unit had been in standby mode for an extended time period. I hit the four buttons like the manual said, all four in quick succession. I also tried the four buttons in many different sequences from what the manual said. When I powered back up the lamp timer was set to zero, finally! I think having the unit in standby for an extended time was the key. The Sony rep really emphasized the need for the unit to be in standby.
Posted on Dec 14, 2007
I have a 60pl9200d/37 philips dlp tv. I replaced the bulb with a brand new one and I am still receiving the bulb issue indicated by the blue lights. Any ideas?
I don't know the model but it would seem a reset would do the trick. See if there is a button on the cpu board and that should do the trick if not try unplugging a re plugging unit . Logic needs reset by a switch or by removing power
Feb 19, 2015 | Philips Televison & Video
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
Mitsubishi HC 900 DLP Projection Lamp Shutdown.
Honestly I would try entering the 'Lamp timer reset' code again. Or the button sequence given to reset the lamp timer.
An issue that may be happening is that something may have happened to the lamp ballast power supply also.
Just a thought.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
Sony VPL PX40 Multimedia Projector Logo
445 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
