Traditional toshiba TV picture problems
My mum has had her widescreen traditional toshiba TV for 7yrs,the picture has now got vertical lines,the colour is distorted and there seems to be a shadow effect on faces.do you know what the problem is likely to be?And if so is it worth fixing or better to just buy a new TV? We have tryed the ariel/sky on another TV but the picture was fine.
  • 1 more comment
  • Diane Murray
    Diane Murray Oct 03, 2007
    Don`t think my description was very good,so will post a better description and a photo.
  • Diane Murray
    Diane Murray Oct 26, 2007
    does anyone know what the problem is by the picture,my above description wasn`t very good
  • Diane Murray
    • any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to poor focusing please check 1 set with focus control fitted on flyback transformer, 2 check focus control wire comes to crt base is loose or some foreign material deposited on it. 3 crt base loose contact. 4 if tv is old then there is a possibility of crt is getting weak. if you are not a technical person do not open set as tv has very high voltage inside. hope this will help.
Posted on Oct 01, 2007
SOURCE:
I my toshiba regza 40rf35ou vertical lines 1/2 of screen for about 12 minutes then great picture
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Vertical line problems to LCD screens are described with illustrations. Surf the site with patience.
Mar 20, 2014 | Toshiba 52HL167 52 in. LCD HDTV
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
What's the difference between traditional foosball (table) players and modern foosball players?
Traditional foosball balls are cheap balls that came about during the 1970's. Today, they are found in low quality foosball tables. The annoying thing about them is the inset lines that make the balls constantly roll even when the table is leveled.
Aug 12, 2012 | Sport & Outdoor - Others
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Traditional photo prints
Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Ekse
