Question about Koss C928 System
Koss C928 DVD/Receiver Home Theater System
My reciever went deaed after one of the hurricanes I was wondering if there was a reset button on this model
3 Suggested Answers
  • 6966 Answers
SOURCE: ciruit or block diagram of pioneer home theater system
The (schematic) circuit diagram is included in the service manual. A downloadable pdf copy is available here.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
  • 79 Answers
SOURCE: home theater koss KS3102 need code to unlock it
heres your answer,,, follow this
I tried this, and it works prefect.
1) You do not need to have any disc in the player.
2) Press "menu" "1" "6" "7" "1" "9"
A special menu will appear with cursor pointing at region.
3) Press "OK", and the current region number is disappear.
4) Press "0", and your player now is region free.
Posted on Jan 22, 2009
  • 112 Answers
SOURCE: dvd hdmi cable into receiver
unhook and reconnect a few times, try with power on and off, (they have to communicate with each other) if not, return receiver and get a new one.. I had this happen with my yamaha...
Posted on Jan 26, 2009
0 characters
1 Points
Disk stuck in Koss c928. DVD powers up and says waiting. How do I get the disk out and how do I reset unit
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
Jan 31, 2010 | Koss C928 System
Need the code for a Panasonic TV remote to operate KS3102
I found a few manuals that may have a similar model number but none of them contain the Koss Receiver, you may want to try a few random receiver numbers and see if anything works, these are all the universal codes i could kind for koss receivers:
Mar 06, 2009 | Koss KS3102 System
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
Salutations robn7499,
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
I hope this helps.
Go Ahead. Use Us.
May 06, 2008 | Koss C928 System
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Sound but no video
Run your yellow cable from the DVD player directly to the TV in the port connected to the red/white cables. If this is already done or doesnt, work, let me know
Jul 26, 2007 | Koss C928 System
Koss KS4102 audio delay problem
You can get the update file from here. Good Luck and let us know how this turns out for you.
Mar 17, 2007 | Koss KS4102 System
Had the same exact problem today. Called and e-mailed Koss today and was told player was made by Koss Electronics, not Koss headphones and that Koss Electronics went out of business. Finally just started hitting random 4 digit combinations and would you believe 0000 works? lol
Sep 18, 2006 | Koss KS3102 System
Koss C928 System Logo
60 people viewed this question
Top Koss Home Theater Systems Experts
Steven Wander
Steven Wander
isaac johny
isaac johny
Are you a Koss Home Theater System Expert? Answer questions, earn points and help others
