SOURCE: Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
SOURCE: i am trying to find
see this link to see the answer, I KNOW the model number isnt the same as yours but having been in the appliance biz for over 30 years i know both are the same capacity and only the features are differenthttp://wiki.answers.com/Q/What_is_the_cu_ft_capacity_of_a_Maytag_washing_machine_LAT8434AAE
SOURCE: Maytag stacked washer/dryer model no. LSE7806ACE;
Hi First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door switch assembly, if the door switch is also fine then the control board should be
replaced. Hope this helps...please post back for further assistance.
Daniel
SOURCE: Dryer making a rumble noise
I suspect the blower wheel that mounts to the motor shaft is loose and needs replacing.
