Question about Scanport GEM 1770DF (White) 17 in.CRT Conventional Monitor
Monitor squiggle I have a Gem 770 monitor purchased in 1999. It has served me well until now. Don't understand adjustments. The picture is distorting.
  • Anonymous Jan 09, 2008
    Mine does the same thing, particularly noticible on fine text, which seem to "squiggle" or look as if they are under water.
    Which adjustment fixes this? Thanks!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If it is adjustment problem then you will have to check it with operating manual picture distortion might be due to horizontal section also if adjustment does not serve the purpose. if you are not a tech person get it done by tech person.
Posted on Oct 01, 2007
Need to reconnect internal video cables
I don't understand what you are trying to say, but this is what I think you're saying. The onboard video card went bad and now you need to put in another one so that you can connect the monitor.
If that's true, you don't put another video card on the motherboard. You go out and purchase a Video Card that goes into one of the available PCI Slots on the back of the computer. It goes inside, but sticks out the back so you can connect the cable from the monitor to it.
Apr 02, 2012 | Compaq Presario 5000 PC Desktop
I have a 17" Gem
You shouldn't need to install software for a monitor to work. What you may have to do though, is configure your display settings to allow an external display. Your laptop might have a function key to do this. Try clicking the function key + the key that looks like a monitor display on your laptops keyboard. This should activate the external display port. You might also try going into the control panel, select display and enable the secondary display. Also a 17 inch display probably has a screen resolution of 1024x768 or 1280x1024 so make sure you don't set the resolution any higher then that or the display might not show anything.
Chris
May 20, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
I am looking for a power plug for my gem monitor #LCAO1F D3350382G
On eBay or Google Product Search or Amazon, search
GEM GL-822 power
or
GEM GL-822 12V 5A
There are a number available there. It is 12V DC, 5A
Apr 19, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Hi I have a Gateway FHD2400 LCD monitor. Everything work fine but all buttons (inlude power and all select buttons) doesn't work.
If the control panel for the monitor does not respond there is no way to replace this. The monitor would have to be replaced if you desire that functionality.
However if the monitor turns on (without the need of the power button) and you do not need to adjust any of the settings then I would use the monitor until it could no longer serve its purpose.
Check the warranty status of the monitor and if it is under warranty you could get a replacement with a properly functioning control panel.
Feb 08, 2011 | Gateway FPD2275W LCD Monitor
Power Issues!
The AC adapter will go into shut down mode if the monitor is drawing too much current due to short circuits in the monitor, but it can also be bad caps in the power supply itself. You can try new adapter or check inside the monitor for shorted components.
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
I have a GEM 17" with power issues!
Sounds like your power supply capacitors are causing the power supply to shut down. Or you have a short in the monitor loading the power supply. You should try a different power supply.
Monitor Mike
Image font not readable blurd
open the monitor if you are technical person look the EHT (a big part in the monitor) has preset attached .read the name focus on it rotate it by screwdriver in active on condition untill you are satisfied
Apr 07, 2010 | Mag Innovision InnoVision XJ 770 Monitor
Screen artifacts on an LCD Monitor
I've read that it may be the power supply for the monitor
Oct 04, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Scanport GEM 1770DF (White) 17 in.CRT Conventional Monitor Logo
97 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
ray gallant
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
