Have a Canon F50 Multipass. The alarm light is flashing. It will not "pull" the paper thru to be copied or to receive a fax. Sounds like wheels are turning but possibly unable to grab the paper..??.. Any ideas? Thanks!
CJ
Attempt to re-surface any replaceable rollers with a brillo or Scotch Bright pad ONLY if you are unable to locate replacement rollers. This will reduce the life of the rollers further and can permanently render them defective
Any rollers in the paper path and in the tray area(s) should have texture and should not be glossy or completely smooth with the exception of hard-plastic rollers used only as guides.
I will give this a try and report back. Thanks for the help!
CJ
I looked into your suggestion. Did not work because the paper is not even getting to the rollers. Paper is loaded; but Canon Multipass F50 says "Load Paper" as if it doesn't recognize that paper is in the tray. It makes a noise like it is trying to pull the paper; but does not. It was working fine on Friday; but first time I tried to use it on Monday morning, I got this error message. Is there some sort of sensor or motor that controls this function? I really like my F50 would like to get it going. Any suggestions? Thanks!
CJ
