Question about Canon Speedlite 550EX TTL Flash
AF Beam Cover
I dropped my 550EX and smashed the AF beam cover(red cover) I was on to Canon UK for a replacement part, but they don't supply spare parts but if I sent it back to them they would repair it at the standard cost of £72.00 anyone know where I could pick up this part ?. Yerman
    Champion:
    Scholar:
  • 216 Answers
Check out LEE Filter or Kodak IR Filter
Place that filter over AF Sensor.
Or try ti find remote(TV/VCR/DVD/radio) control unit with a large filter over led.
You can still glue those broken part and glued it back as close as possible.
atdlee@netzero.com
Posted on Jan 26, 2008
3 Suggested Answers
Joe_Rex
  • 114 Answers
SOURCE: AF Beam Cover for 550EX Speedlite
I broke a lens once and just went and bought a New / Used Bounce Flash that had a uneversal flash-boot. most cameras have a flash plug in to acommidate Auto Flash Modes. If You Know how to test Cameras and Adjustable 'Bounce" flashes like yours PAWN SHOPS are a PARADISE.
Posted on Oct 09, 2007
  • 4 Answers
http://www.uscamera.com/550ex.htm  i bought hot shoe foot for my 430ex. they ship international.
Posted on Oct 10, 2007
2008 Saturn aura wont start after trying to put rt.low lowbeam replacement
On the inside of the lid is a diagram .
The headlamps may be turned ON 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the AUTO position, for automatic lamp control (ALC). During ALC, the headlamps will be OFF in daylight conditions, or low beam operation in low light conditions. Battery positive voltage is supplied to the low beam relay and the high beam relay in the underhood fuse block. When low beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the low beam relay. This activates the relay and the relay supplies voltage to the left hand low beam headlamp through the LH LOW BEAM fuse and to the right hand low beam headlamp through the RH LOW BEAM fuse. Ground for the left hand low beam headlamp is provided at G101. Ground for the right hand low beam headlamp is provided at G102. When high beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the high beam relay. This activates the relay and the relay supplies voltage to the left hand high beam headlamp through the LH HIGH BEAM fuse and to the right hand high beam headlamp through the RH HIGH BEAM fuse. Ground for the left hand high beam headlamp is provided at G101. Ground for the right hand high beam headlamp is provided at G102.
Aug 14, 2017 | Saturn Cars & Trucks
Oct 09, 2007 | Canon Speedlite 550EX TTL Flash
My Canon XTi autofocus beep and light don't work
Be sure that beep and AF assist beam is turned on. You can check this in camera menu first page and beam in custom functions under number 05.
Jul 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Turn off focus assist beam on Nikon
Custom Setting Menu A, autofocus, setting A3 "Built-in AF-assist illuminator".
174 in my D90 manual.
"Choose whether the built-in AF-assist illuminator lights to assist the focus operation when lighting is poor"
Jul 06, 2009 | Nikon D90 Body Only Digital Camera
Replace low beam headlamp, passenger side, 2004 Navigator
Remove the front radiator air deflector.
Remove the three bolts and the headlamp assembly.
    • Disconnect the electrical connectors.
Remove the headlamp bulb protective cover.
1 Low beam cover. 2 High beam cover.
Feb 13, 2009 | 2003 Lincoln Navigator
Passenger front headlamp bulb replacement required
Remove the carpet covering the inside near the headlight. Remove round rubber plug. (pull hard, the plug has NO WIRES coming out of it) Use the 5mm wrench that is in the toolkit. (toolkit is behind the spare tire). Turn the wrench 180 degrees and the whole headlight assembly will loosen. Pull out the whole assembly. Remove plastic end cap. The high beam, low beam and parking bulbs are all right inside that cover. Just did my 2002 for the first time. This is also covered in the manual if you have one. Thanks, max327@aol.com
Feb 10, 2009 | 2000 Porsche Boxster
Powershot SD750, AF-assist beam / Red Eye reduction lamp / Self timer Lamp
Hi
The part is probably defective and needs to be replaced, or its possible if the camera was dropped it needs to be unplugged and then plugged back in... maybe it's just not making full contact.
If you need the camera repaired, thats what we do, we are a digital camera repair business. Just let us know, we can check it out for you. If you want to buy just the part and try it yourself feel free to contact me and I will see if I can buy just that small piece or not.
Good luck from
Darntoothysam com
Sep 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Green Light Won't Turn Off
turn off the red eye reduction mate,
Aug 08, 2008 | Canon PowerShot G7 Digital Camera
Turning af beam off
The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
Apr 21, 2008 | Canon PowerShot A520 Digital Camera
Canon Speedlite 550EX TTL Flash Logo
211 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
