Try using a phone to get onto your settings for your modem and check connectivity, which i suspect is fine, the problem is probably with your WIFI card, so try using a LAN cable to connect to your modem directly using port 4. Message back after youv'e done these steps and we'll try problem solving the issues. best regards.
I dont have an active phone line and I only tried to connect to my laptot with LAN cable- with 3 different LAN cables and I also tried all 4 ports. I didnt try to connect via WIFI because I dont see any Wifi signal from the modem (I tried turning the Wifi on the modem on and off but no signal appeared) The speccific modem is Modem Comtrend VR 3026e v2
SOURCE: asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
SOURCE: Cant access router setup
If you type in http://10.0.0.2 to the adress line on your web browser, you should see a login window for the router. I think it is the wrong address. I think you should first RESET the router. Look for a little hole about the size of a pencil point. Stick a paperclip in and hold it in for about 1 minute. This should reset the router to factory settings.
If you have the manual, it should tell you how to access its setup pages. This is a modem and router in one. You must have an ADSL phone connection to an ISP. You must have the ISP's information to connect to their network. This information is needed to set the modem part of the router to log onto the internet through the ISP. Best of luck.
SOURCE: I have used my SMC rouoter to connect to my
SOURCE: I tried to connect internet but i could not configure my modem..
are you trying the same address of the router?
with which browser you tried?try changing it and use internet explorer.
