I want to be able to watch things on my tv from my laptop i was told you can adjust certain things under the control panel to get it to work but I dont know what to change I am using a VGA to Composite cable(Red, Green, Blue) My Laptop is a HP G60 Running Vista 32 bit and has a Nvidia 8200M G video card my tv is not hdtv but does have composite hook ups i have the audio working right but when i hook them up the video on the screen is distorted you can see anything but what looks to be 4 boxes and pink around them and its flickering the whole time any help would be appreciated thanks in advance
Comments:
Apr 29, 2009
- ive already tried lowering the resolution to 640x480 that made it worse
i want to be able to see stuff from my laptop on to my tv i know there is a way to use this cable i got with out having to buy a converter box cuz ive heard of people doing it and also lol why else would the sell them anyways im mainly wanting it so i can watch netflix on my tv
firstly, you should be getting your connection by going to the control panel and going to display and going to advanced and then the video card tab of your video card. The window asks you to find any external monitors. If this is how you got this far then you have to change your video resolution manually by going back to the first window in display and lowering your resolution to 320 by 240 ( 640 by 480 if that is as low as it goes. Good luck
I'm trying to install this program and it says I don't have the DVC100 disk or something, am I...
(More)
I'm trying to install this program and it says I don't have the DVC100 disk or something, am I supposed to have bought a seperate disk to install it? Also when it gets to the part where I can "Select total recording time: Automatic, Good Better or Best" the section won't let me type in the minutes to "Start Recording" The camera I'm trying to get the videos off of is a Sony TRV57 it's pretty old- is this why I'm having the problem, is my camera too old to work with this software?
Just installed the e-Geforce 6200 to replace an original equipment bad graphics card on Dell 4600...
(More)
Just installed the e-Geforce 6200 to replace an original equipment bad graphics card on Dell 4600 (2.6GHz, 2 Meg RAM, Win XP). Having a terrible time with problems with scrolling delay and choppiness. Either with mouse wheel or scroll bar. With scroll bar sometimes even get a short hourglass. Screen paint is slow and screen scrolls as if it were multiple pages not one big page. Occurs with IE as well as some MS applications such as Word. Tried IE with and without Smooth Scrolling with no difference. This delay is really frustrating and makes it hard to use this PC.
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS...
(More)
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS IS A READING i GET, WHEN MY MONITOR, MESS'S UP. IT SEEMS THAT WHEN MY COUMPUTER IS COLD(JUST TURNED ON) T5082-eMachines. It (bilt in ATI) don't have enough power? to run the screen AOC- lcd monitor it worked fine at first. but when windo's started down loading all there up dates to fix Vista, it got a lot worse. I have wavey line's on screen can't read any thing for about 15min. OK I gess or hope I'v given you enough info. ? Thanks , James
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card...
(More)
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card and use the onboard graphics, system never hangs. whenever i reinstall the card. same thing happens.
