Question about Nokia N70 Cellular Phone
Key Pad replacement
I want to replace Key pad and I got a new key pad in KL. Could you tell me how to open front case?
  • 33 Answers
Hi there, I could try my best to explain, but I feel I would fail hopelessly!So instead if you go here: http://www.uselessinfo.pwp.blueyonder.co.uk/dismantlen70.htm it will give you step by step instructions with pictures telling you how to take off the cover. Hope this sorts you out :) Si
Posted on Oct 03, 2007
SOURCE:
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
I have a Kenmore Double Oven that's eiving a Code 7 and beeping
Hello,this code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks
Jun 02, 2010 | Kenmore 43389 Electric Double Oven
Oven blinking code F7?
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
Determine if problem is with the Key Panel or Control by:
Dec 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Replace a key pad on pavilion zd8000 Problem
laptop back side indicate the key board screw
open the screw then replce new one
Nov 14, 2009 | HP Computers & Internet
On rbd275pdb12 what is the code E6 F2 means
HI, this is referring to the cancel key on your key pad. It is stuck open. follow the procedure below.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Oct 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Ky pad not functiong lttr not typying
Please state what you are facing also tell us did you open it casing or any chances for the keypad filim cable detached
it can be due to the non connectivity or device driver issue, The best solution is to connect a PS2 or USB external key board and check its working or not then we can assume whether its a driver problem or a physical problem. New keyboard is also available you can replace it
Jul 04, 2008 | Toshiba Satellite M115-S3094 Notebook
Nokia N70 Cellular Phone Logo
54 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
