Question about HP LaserJet 3050 All-In-One Printer
Incorrect Fax Number showing on sent Faxes
On the recipient's fax (sent from my machine) it is showing that it has come from a different fax number to the one it is actually going from. How do you change the outgoing fax number printed on recipients copy?
  • sarahkerry Oct 03, 2007
    Brilliant! Thank you so much.
    Kind regards
  • Anonymous Mar 12, 2014
    I'm trying to send a fax to a different # but it is sent to my doctor's office fax machine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 171 Answers
The solution given is correct. happy faxing OMNIPRESENT
Posted on Oct 02, 2007
  • HP Master
  • 705 Answers
Try This: To set the fax header To set or change the fax header information, complete the following steps. If you need help entering any information, see Enter text from the control panel. 1. On the control panel, press Menu. 2. Use the < or the > button to select Fax Setup, and then press (Tick) 3. Use the < or the > button to select Fax Header, and then press (Tick) 4. Use the alphanumeric buttons to enter your fax number, and then press (Tick) 5. Use the alphanumeric buttons to enter your company name, and then press (Tick) NOTE The maximum number of characters allowed in the fax number is 20. The maximum number of characters allowed in the company name is 40.
SOURCE:
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
Fax problem
Pending faxes are faxes whose transmission has been delayed either deliberately or unintentionally. Normally, when a fax cannot be sent at the first attempt, the fax machine will redial the recipient's number. If you choose to delay sending a fax, the machine will send it at the time you select for transmission. During the delay period and at any point up to completion of the call, you can cancel the delayed transmission by deleting the fax from the Pending Faxes queue. To do this:
Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
Press Select to delete the pending fax.
In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
Press Options (once only). The Pending Faxes menu will now display None.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
HP LaserJet 3050 All-In-One Printer Logo
240 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
