Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Seems like to high a gain on set
After a software update to my Insight Cable boxes (don't really know if this caused th problem or not) my picture on the Daewoo is heavily pixalated, on all channels, though some are worse than others, like the gain has been cranked all the way up. Anyone have any itdeas about cause and effective remedy? set is 2 years old
    Genius:
  • 1,139 Answers
This is not a Television issue. I think that your cable provider needs to re-do your software upgrade. The reason I say this is because the problem did not occur until the cable box was upgraded.
Posted on Oct 03, 2007
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The channels 03-30 or so are very grainy and don't have a very clear picture. It seems like the higher the channel the better the picture. The cable is high quality HD cable straight from the tv to the...
If you are using the TV's tuner and an aerial, the aerial has a problem , (one of the reflectors/elements has come off or is bent) or the tuner unit has gone low gain at the lower frequencies.
Have a look outside at your aerial. Or there is a poor connection in the aerial system.
Hope that helps
Jan 02, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
The picture is too large, almost as if it is on zoom, so the edges of the picture are cut off. How do I fix it?
check and see if you have a zoom button on the TV remote
If your hooked to a cable box call the provider because some of the cable boxes have a setting that will cause this issue
Dec 04, 2010 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I cannot briing in a picture. Upper left corner of picture says it is on channel 4...upper right corner "no programs availab le"How do I program TV to bring in a picture.; I am on Insight Cable.
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
Dec 17, 2009 | Televison & Video
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Tv-- signal strength normal but signal on all channels "blipping" down intermittently causing freezing of picture. Have replaced aerial with high gain antennae together with aerial cable and...
When ever the picture freezes intermittendly the problem is usually poor connection on the signal line (antenna or connection on tv) or poor reception. Could be the tuner if the tv has one.To eliminate the tuner possibility try anther tv set if possible.
If you still cannot figure out the problem,let me know what kind of set up you have connected to your tv set.
Do you have a satellite or cable box and if you have splitters.
Jul 11, 2008 | LG Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
