When i place new batery AA within a minute the camera shut off low battery. I can't work and also other battery give the same problem
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Testimonial: "Thank you for your answer but a used several good and new are rechargable battaries. The same where i in the beginning never have problems with. I think the camera is damaged???"
SOURCE: Low Battery Power
Clean battery contact on the cover and if possible on the far side of the battery compartment (spring and metal connector). You can use fine abrasive such as 3m or scotchbrite. Oxidation buildup increases the reistance and the camera ' thinks' that the battery is depleted.
