Question about Dryers
Dryer electric cord
I recently purchased a used Frigidaire dryer (very good condition), but the owner retained the cord for his new dryer. He told me that I would need a 3 prong cord to replace it. An electrician came in the house to give a bid on installing a 220 outlet for the dryer (we don't have one yet) and he feels that I need a 4 prong cord. How do I determine which cord is the correct one (3 or 4)? Sorry, I don't have the model number with me, but could get it if necessary.
  • 625 Answers
The national electrical code requires the installation of a four wire system for ALL 240 volt equipment. He will be putting in a four wire dryer receptacle. The pigtail you'll need will be a standard four wire pigtail. The way it is connected is: the red and black go to the two outermost terminals, the white goes to the center terminal and the green goes to a good chassis ground point. If there is a jumper strap from the center terminal to the chassis ground point it must be removed.
Posted on Oct 02, 2007
SOURCE:
What size screw is use to install the dryer cord to the dryer terminal
Hello friend, thank you for allowing me the opportunity to assist you!
The screws that are used to install the dryer cord to your Frigidaire dryer terminal are stainless 1/4 inch screws. I hope this is helpful. -Matt
Aug 19, 2014 | Frigidaire FER641FS Electric Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Mar 22, 2011 | LG Dryers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I had an older second hand dryer and about 4 months after we moved into a new appartment it started sparking when I hit the start button. It did not happen every time. The spark came from behind the dryer...
it's not the dryers?change the outlet and the cord.you could have damaged the dryers too.you answered all your own questions,change them out before you have a fire.good luck
Dec 21, 2010 | Frigidaire Electric Dryer
We recently purchased a GE dryer and were told it is electric or gas operated, the dryer runs but is not heating up. i think it might be because it isnt getting enough electricitry, but i cant get the back...
If your dryer came with a regular grounded cord attached, it is a gas dryer, and you will have to hook up a gas line to the 3/8 pipe nipple at the lower left corner (when viewed from behind). The 4 prong power cord is only used for electric only models. If still unsure, post the model number from the sticker inside the door of the dryer.
Oct 04, 2009 | GE DBXR463EBWW Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Frigidaire Dryers
Frigidaire electric dryer....
venting porbelm. do you have the vent going outside of the house or it is just indoor???
make sure there is nothing in the vent pipe.
Oct 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
New Dryer was purchased -- Tenant tells me he now requires higher voltage
Hello Paulcolletti,
I am not sure what you mean with your question.. Electric dryers typically use either 3 pole or 4 pole plugs that mate with the corresponding receptacle. If you already had an electric dryer there before, you need to make sure your power cord matches the receptacle. If it does not, most home goods stores ( like Home Depoit/ Lowes) and others carry the molded cord sets for that application and are reasonably easy to install. I fail to understand the low voltage versus high voltage comment as it pertains to a dryer. Please elaborate on this and maybe I can assist with a solution.. Good Luck...
Oct 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
224 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
