SOURCE: audi a4 1995 central locking problem
Hi there.
I had exactly the same problem and there are 2 ways of solving it. The first is to pay your Audi Service Centre £350-£550 to replace it for you and the second way is to do it yourself which will cost well under £100 (depending on ebay). Firstly check the Central Locking Pump to make sure the hoses haven't come off. This is located in the very back right hand corner of the boot so you will need to remove the carpet and internal trim and you will see a block of sponge. Carefully lift the top off this and you will see the pump sat inside it.
Actually there is a great set of photos online to help you and I will add the link for you at the end. If the hoses are still connected and not leaking it is very likely that the internal compressor wheel has shattered (quite a common fault). I believe it is possible to open the pump and replace this wheel (in fact there is one for sale on a very popular auction site at the moment) but my own preference was to simply buy a whole new pump and replace that (£16.00 + £8 p+p off the same auction site).
The most important thing for you to remember is that when you look to buy a replacement pump you need to find one with the EXACT same serial number. The one in the diagram shown is
8LO 862 257 N but I have a sneaky feeling yours might end in an A.
Anyway, I hope this is of some help and dont worry about the connections as both air connectors and all 3 electrical ones are different sizes and will only fit in one place each.
Good luck.
Rik
http://www.audiworld.com/tech/elec131.shtml
SOURCE: VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
SOURCE: Ford mondeo 02plt. Central locking fault
Hi I have a Toyota Avensis 4d saloon 2.0 TD 1998 R reg the problem i have is the central locking does not work it stopped working after a heavy frost
SOURCE: land rover discovery central locking.
No, likely to be caused by the actuators in the lock mechanism failing usually causing the door to remain locked. The boor door can also fail this way, as do the front side doors. Replacement requires the whole lock unit to be replaced at a cost of roughly £60 a lock, and a hours work. Helps if you have small hands. Requires a full strip down of the door and you will need the lock unit, trim clips (a few quid) and a trim removal tool (tenner). You can bodge with a flat head screwdriver, but the tool does help prevent damage to the clips & trim panel.
SOURCE: central door lock system not working
CHECK THE DOOR LOCKS MAIN FUSE.
Testimonial: "Great, it helps"
