The 303 error would indicate a failing Hard Drive, but try the following first and then re-run the HDD test - if it still fails, it would look like you'll need to replace the drive.
Click the Start Menu, click Computer, left click Local Disc C once to highlight it, right click Local Disc C and select Properties. Click the Tools tab and then click the button to 'Check the Drive for Errors'. In the following window make sure both boxes are ticked and then click Start. Part of this process will require a restart to check the drive.
SOURCE: how to get password from hdd password error code acer aspire 4315
Is the error message coming before bios starts to load XP from harddisk, or after?
If it is coming after XP starts then it may be driver issue.
If it is coming before XP, then it may be a question of incorrect bios for the hardware in your laptop.
SOURCE: cannot install audio drivers for hp compaq c733tu
I have
an COMPAQ Presario C700 bought in India actually it is a Compaq C733TU
Follow
the following steps in order
1)
Intel Chipset SM Bus Controller: get it from Intel Site Search ”infinst_autol.exe”
or “INF Update Utility” for Chipset 9xx (I think it is 945 or 965) on google .Search
for Intel Chipset Identification Utility to know you chipset version. Don’t
download or install the Zip version of the INF Update Utility
2)
Video Drivers for 965 Express Graphics “win2k_xp14311.exe” “intel graphics
driver win2k_xp14311.exe” you can download the latest version of Intel Graphics
Depending upon your Chipset version.
3)
Unknown device in device manager is actually (check properties of Unknown
device has something like ACPI\HPQ0006 as one of the details download drivers
which I am sharing) HP Quick launch Button Software no need to download the whole
stupid software. The driver is just 11 KB while actual download of the full
thing is 20 something MB
I shall
upload it to some sharing site or put your email below as reply
http://rapidshare.com/files/137560123/HP_Quick_Launch_Buttons_Driver.zip.html
(here is one link only 6KB zip file scan it )
4)
Install UAA: You need to have Microsoft Universal Audio Architecture (UAA) Bus
Driver for High Definition Audio installed on the computer before installing
the audio driver [“sp32395”] install this do not unzip and try to install
Microsoft
Windows XP SP2 Universal Audio Architecture Update (Q888111):::::::This is what
HP calls it
Here is the link for UAA: ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32395.exe
5)
Audio Device is sp34200 is Conexant Hi-Def audio unzip using WinRAR or 7 Zip (execution
of SP34200.exe doesn’t work) (The mike doesn’t work for me)
URL
: ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
1. Click on Start and select Run. Now type devmgmt.msc
and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and
click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from
the list.
6. Click Next and then click Have Disk.
7. Click Browse sp34200 folder and the double click the V32 folder. Select the .inf file, click
open and Continue with the onscreen instructions.
6)
Modem is “sp33890” HDAUDIO Soft Data Fax Modem with
SmartCP : (execution of
SP33890.exe doesn’t work) unzip using WinRAR or 7 Zip
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
1.Right click on "Modem device on High Definition Audio Bus" and
2. Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to
install"
4. Click Next and then select "Modem" from the list.
5. Click Next and then click Have Disk.
6. Click Browse to C:\sp33890 folder and select the .inf
file and click open and Continue with the onscreen instructions.
7) Wifi
is Atheros AR5008 Wireless Network Adapter (not sure but it works) “Atheros xp32-6.0.3.85.zip”
370 KB
“11a/b/g
Wireless LAN Mini PCI Adapter II”
http://www.atheros.cz/download/drivers/ar5008/xp32-6.0.3.85.zip
I
couldn’t get the mike to work……….i don’t use it anyway
Good
Luck……..
SOURCE: Error Code 815
If you do not want to connect to the internet through a dial up connection. . .
Solution:
Using Windows Vista
1. Open the Control Panel
2. Select Classic View on the left
3. Open Internet Options
4. Click on Connections
5. Select "Never dial a connection"
6. Click Apply
7. Click OK
8. close all browsers and restart your computer (suggested)
SOURCE: how to install xp in hp dv 2918tx laptop
This is a Vista laptop with a SATA hard drive. Windows XP does not have the SATA drivers, you therefore must slipstream the drivers to a new installation disk
SOURCE: hp 530 laptop - Bad directsound driver error code 88780078
sounds like the sound card is dying, or the sound codec's are wrong.
