Question about HP DeskJet F380 All-In-One Printer
HP Deskjet F380 Paper Problem
Hi, My F380 just will not print out a sheet of stickers (Avery) which is marginally thicker than normal A4. Have had no probs with previous printers but this one prints badly off centre, lop-sided - seems to be a problem in the uptake of the sheet resulting in badly aligned print jobs. Any help would be appreciated!
  • 2 more comments
  • Anonymous Feb 09, 2008
    Yes my Machine is L380. The Machine Not print My message. It prints only His statistica data.
  • Anonymous Mar 22, 2008
    f380
  • utube_intern Aug 29, 2008
    driver for hp f380
  • Anonymous Sep 25, 2008
    uykuyk
Xsfsfsfsfsf
Posted on Apr 06, 2008
Pls help me to download hp f380 all-in-one software
Posted on Jan 13, 2008
There is a queue of items to be printed but I get nothing
Posted on Dec 30, 2007
Download full Driver Or Software for Hp Soultion Centre F380
Posted on Dec 13, 2007
Http://www.nodevice.com/driver/company/Hewlett-Packard/page3.html
Posted on Oct 15, 2007
SOURCE:
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Print Garbage
The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
985 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
