FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
Hard drive stops booting (by 5 users)
posted by deaconmoon on Oct 01, 2007
hard drive stops booting
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by anni_tomich, posted on Jul 15, 2008
i have a lacie external hard drive 250 gb. my computer doesnt open it anymore. i have all my information on it. i used it the other day and i shut down the computer with it connected. it didnt shut down so i ripped it out (i know, i know, badly done) and it proceeded to shut down. now when i connect it, nothing prompts me that it is connected. it doesnt ask me if i want to view files on it nor does it show up in 'my computer'. dont know what to dooo
Comment by Pabpicaso, posted on Jul 10, 2008
Hi guys,
My problem seems to be simple but tough to me, i have got a Samsung M60 notepad pc, i removed the HDD which is 200gb and is SATA and connects to the M/board via a ribbon cable connector. I was doing some Data recovery sort off using stellar phoenix software. Now when i replaced my HDD back it could not be detected by the Laptop but externally is ok. It gives a message that Operating System Not found. When i go to bios I set everything to default still not working can somebody help please Thanks
Comment by BrianM8614, posted on Jun 03, 2008
hard drive isn't seen by computer
Comment by Guest, posted on Apr 06, 2008
Harddisk wordt niet meer herkend door PC.
Ook niet met een externe behuizing en USB2 aansluiting.
Met Getdataback wordt hij na enige tijd wel herkend.
De disk staat vol met foto's.
Hoe haal ik die eraf ???
Wie kan mij helpen aub.????
Best Solution
posted on Oct 03, 2007
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 87%, 2148 votes
If your computer stops booting from the hard drive and is asking for a boot disk, then:
1. The motherboard/PC is no longer recognizing the hard disk;
1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit.
2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD.
If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced.
If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair".
Hope this be of some help/idea. Post back how things stand or should you need additional information.
good luck and kind regards.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP (EK423AA) 300 GB Hard Drive Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive BUSlink (BDH-60-U2) (BDH60U2) 60 GB Hard Drive Compaq (349239B21) 250 GB Hard Drive Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive
Can you Help with these Hard Drives problems?
Hard Drives
Dowload Drive for my...
Dowload Drive for my... Answer This...
Acomdata HybridDrive E5 Hard Drive
Computer doesn't see the usb...
usb cable connected to... Answer This...
Maxtor 160GB OneTouch III Mini USB 2.0...
Problem starting up Maxtor 160...
I don't know if this problem... Answer This...
LaCie 500GB FireWire-400 Porsche - 7.2K 500...
Lacie 500Gb Hard Drive Porsche...
Hard drive not being recognised... Answer This...
Hard Drives
External Corrupted
exactly it was say: F:\is... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
