Http://www.kellys-korner-xp.com/regs_edits/xp_taskbar_desktop_fixall.vbs
run this program
http://forums.techguy.org/windows-xp/1058260-windows-xp-desktop-icons-taskbar.html
SOURCE: windows xp service pack 2
I think the screen resolution of your monitor have been changed.
To restore them back, you can go to display properties, from control panel and change the resolution under the settings tab.
Or
Your monitor settings can be made right from the buttons available from the outer panel if that is the problem.
SOURCE: windows xp sp3 problem
Best answer is likely to uninstall and reinstall SP3. If it remains a problem, free support available from MS, as it is a Windows Update issue. Visit http://www.update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us for more info. Thanks for rating FixYa!
SOURCE: not shown desktop
If you right click on the desktop, and go to Properties, do you have a theme loaded? Make sure you have one of the standard windows themes.
Also, check the "Desktop" tab, and make sure you haven't set it to an all black wallpaper.
SOURCE: no voice in vista os derivers shown ok
remove the drivers and install it again ... ur issue will be resolved ...
sound problem is very regular with vista
SOURCE: Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
