Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD420 - Stuck in wash cycle
Hi All, Need your advice....Suddenly our machine has started to get stuck in wash cycle for 2-3 hours, then we have to swith it manually to rinse&spin. This only happens every 2 or 3 washes...so very frustrating. Also some cycles do not start at all (lights just flash) Thanks in advance for your advice Cheers Steve
  • 6 more comments
  • Anonymous Nov 22, 2007
    On/Off indicator light flashes rapidly when trying to swith machine on. Top 2 lights to the left also flash, machine will not start. Model WD420, 5 years old.
  • superman69 Mar 11, 2008
    wd420 stuck in wash cycle for 2-4 hours in 30 minute programme.
  • shaz d May 26, 2008
    hyaaa ,,, put load in at 11pm.. still hadnt finished at 2.30pm ..
    put it on rinse cycle ,, that took 1hr before turned machine off. i ended up just pumping water out as needed clothes wet and unspun.
    so will try cleaning pump tomorrow :( wish me luck lol
    shaz d
  • Mickey81 Jun 19, 2008
    Hotpoint WD420 Washer / Dryer - My machine gets stuck during the rinse and spin on a normal cycle. It'll just stop doing anything and they'll still be aload of water inside the washer. I can switch it over to the drain setting and it'll drain out all the water but when I put it on to final spin it'll just keep going all night but without ever getting upto speed.
  • siobhanl Jul 10, 2008
    HI
    My washing machine is just over a year old and it has started to get stuck on the rinse and spin cycle, sometimes the water staying and others the water drains. In either case the washing machine eventually starts flashing the 2nd and 4th light along with the on/off light. I'm slowly taking it apart but can't find any blockage!
  • muschioverde Jul 18, 2008
    I've a Hotpoint WD420 and the same problem. Stuck with flashing and three bottons flashing on the left (it should be a suggest that it wants to give to us). Anybody does know what happens to my washmachine?
    Thanks so much in advanced.
  • kebabandchip Aug 24, 2008
    WD420 WASHER DRYER STUCK IN WASH MODE AND NOT DRYING
    I had both these probs but luckly enough it was covered with my garrantee so engineer came out popped of the top and hooked his laptop up to it and told me the program had something missing, and there and then flashed the programmer for me.
    Also he said it is not cold supplie only as on a lot of these models so on went the hot and cold supplie and it now runs like a dream.
    I have noticed with this machine that the clothes are very hot like a damp feel when you open the door after drying i find a quick airing solves it ie just wave them about before you fold them they just need to cool down thats all.
    ELAG
    this site contains most manuals for macines this adress will take you to the hotpoint wd420 pdf manual but the site has loads more for free all you have to do is give email adress good luck hope this helps
    ELAG
    http://laundry.manualsonline.com/manuals...
    President:
  • 1,294 Answers
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
  • prem mathew Dec 27, 2007
    Press "end of cycle" button for over 5 seconds. Flashing may stop. Then try to start from beginning according to your normal wash. If this does not work, plug off the wall, open up behind the machine, check to see if all connections are tightly secured. Possible connections come loose due to vibrations in the machine over time. Specially the connectors from the control board to the motor.
    New Friend:
  • 3 Answers
When the machine stays on 'wash', leaving water inside - with mine it was the connection to the heater (Spade connector behind the plastic panel at lower rear. Squeezed slightly with pliers, Bingo!
Posted on Jan 07, 2010
There are several possible reasons for this, but essentially the water is not pumping out of the machiene. this can be from blocked pumps with hair to a blocked outlet pipe or even the drain you have the pipe plugged into. I do not tend to find that its an expensive pc board or even need to replace the pump but just clean the pipes from the pump to the outside drain, all of them.
If you have cleaned out the pump but still the water drains as if by gravity and not by fource then you can change the motor brushes by hand.
Rob
Posted on Jan 22, 2009
Throw in skip / inherent Design fault with washer dryer circuit board dies when condensate drips onto it from a cover that Hotpoint didn't seal properly. It will reset if left switched off for a long period but problem won't go away unless the service engineer reseals the offending part and shields circuit boards from condensate
Posted on Dec 18, 2007
    Problem Solver:
  • 8 Answers
Check heater element . ,
Posted on Nov 09, 2007
SOURCE:
When turned on won't fill just starts agitating
I would say u need to check both the water pressure swith which is what signals machine to go into agitation. and the water level inlet valve which may be defective in the coils? Is the timer stuck on wash? can u manually change the cycle? water is turned on?
Jun 23, 2015 | Washing Machines
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
MACHINE WON'T PUMP WATER OUT, STARTS WASH CYCLE THE WASHER GETS TO POINT WHERE IT SHOULD PUMP WATER THEN JUST STOPS. TRIED TO MOVE IT ONTO DIFFERENT SETTING TO PUMP OUT AND WOULD NOT WORK.
SOUND LIKE THE LID SWITH
YOU CAN BYPASS UNDER THE CONSOL 2 PLUG 1 IS POWER THE 2ND IS YOUR LID SWITH SPLICE WIRES LEAVE THE GREEN WIRE PLUG BACK TOGETHER
Jan 31, 2010 | Washing Machines
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
My washer is stuck on the wool cycle and won't wash,change cycles
I had the exact problem. I am not sure if this is the fix, but I unplugged the machine over a few hours, then plugged it back in. It stayed off for 20 seconds and then went back to the wool cycle. In frustration, I opened the lid while running my fingers over the cycle select buttons quickly back and forth two times, as I closed the lid, the display cleared and the machine returned to normal, so far anyway. It seemed as if some moisture had gotten in the controls somehow. It was a very humid day and I think that was the problem,after all. My machine is over ten years old, and the only other problem was a clogged drain pump. I used advice from this website to fix that, and saved 300 on repairs at least
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
7,622 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
