Photoconductor unit setting error appeared,the same was inserted again after necessary repair but still photoconductor unit setting error appears.
SOURCE: Replace Color Dev. Unit (Type B) alert
You stated message said replace dev units. Why did you replace the PCU's? There is a difference. The color pcu's can go into any color slot but the deverloper units can only go in one slot. The dev units have a u shaped green plastic part on the front of them and just slide out. The pcus have a little lever and have to be released.
SOURCE: AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
