Question about DeLonghi RT200 Retro 2-Slice Toaster
Toaster Does Not Work...
My DeLonghi toaster stopped working after I dropped the plug prongs (only the area which plug into the outlet) in some water near my sink by accident. I didn't think anything of it, but when i went to plug it in the next day whole thing acts as if its not even plugged in anymore. HELP! I miss my toast!
    Problem Solver:
  • 11 Answers
You may hve gotten some moisture inside the plug, just leave it for a few days to let it dry out, if the problem persists, send an e-mail to the following:
li199065@hotmail.com
Posted on Dec 06, 2007
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
The prong on the plug snapped off in the outlet
Hello. You can replace the plug your self with a good quality 120 volt, 60 Hz plug, or you can take the toaster to most hardware stores or electrical supply stores where they will repair it for you. Joe
Apr 27, 2010 | Dualit CTS4E 4-Slice Toaster
Right side stopped working
In the manual:
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
Aug 15, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
The toaster does not heat and it's only 6 mos. old.
1. check outlet where you plug in your toaster with lamp or vacuum.
jiggle plug of lamp or vacuum while plugged in to check for bad outlet.
if lamp or vacuum do not work, check breaker panel/fuse box for tripped breaker/blown fuse.
if breaker/fuse okay, replace outlet.
if lamp or vacuum work okay, go to next step
2. plug toaster back into outlet, jiggle plug, then jiggle cord at plug, then jiggle cord at toaster.
this checks for intermittent power cord.
if cord okay, check that the toaster lever or toast basket are not blocked from going completely down.
might be a bit of bread, muffin, bagel that blocks the basket.
if all okay, you need other solutions.....
Jul 09, 2009 | Back to Basics Kitchen Appliances - Others
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
Russell Hobbs 9376 Classic 2-Slice Toaster
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
Dec 27, 2008 | Russell Hobbs 9376 Classic 2-Slice Toaster
Toaster/oven
Could be the timer switch. They will suddenly stop working all at once or work intermittantly. Unless it's a Delonghi you may have a very hard time finding the part you need. If the switch is a DKJ/1-60 you will not find one but there is a Delonghi switch that you can use which you can find at www.thegourmetdepotco.com or www.applianceparts.com . The Delonghi part # is 5218104600 to replace a DKJ/1-60
Mar 05, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
DeLonghi RT200 Retro 2-Slice Toaster Logo
223 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Gerry Harvey
Gerry Harvey
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
