Question about Kenmore 15129 Built-in Dishwasher
Water is not completely draining
I still have water in the bottom of the dishwaster. I have hit the drain button, but nothing has happened. I just replaced a sink disponsal, but turned on the valves afterwards.
  • Anonymous May 06, 2009
    ah gee.... thanks for the answer... so dang ridiculous to have that thing in there to begin with... why don't they eliminate that step...jeepers...you saved me a ton this evening...thanks
Did you take out the "knock out" plug, off the new sink disposal, before you hooked the drain hose from the dishwasher to it?
Posted on Oct 17, 2007
SOURCE:
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
When the dishwasher completes washing the dishes are clean and dry but the water doesn't completely drain. There is about 1 inch of water at the bottom.
TYPICALLY A D/W WILL RETAIN A SMALL AMOUNT OF WATER IN THE SUMP OF THE MACHINE IF YOUR DISHES ARE CLEAN AND DRY I WOULD NOT WORRY IF YOU HAVE DIRTY STANDING WATER IN THE SUMP FIRST OFF GO TO WHERE IT DRAINS UNDER THE SINK GET A 5 GALLON PAIL AND UN HOOK THE HOSE BLACK GREY OR OFF WHITE UN HOOK HOSE AND HIT CANCEL DRAIN BUTTON ON D/W AND SEE IF WATER IS NOW GONE THE PORT WHERE IT DRAINS MIGHT BE PLUGGED IF IT DOES NO CLEAR THE WATER YOU MIGHT HAVE IN THE PAST BROKE A GLASS IN THE MACHINE AND A SMALL PIECE HAS LODGED ITS WAY IN FRONT OF THE DRAIN PASSAGE DEPENDING WHAT MACHINE YOU HAVE DETERMINES HOW THE ISSUE IS SOLVED
Jul 20, 2009 | Dishwashers
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whirlpool Dishwasher DU850DWGX1 won't completely drain
Check the drain pump, it's located behind the toe panel near the front of the machine. Also pull the lower spray arm and filter screen, see if anything is stuck in the sump.
Feb 23, 2009 | Dishwashers
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dishwasher has lights but won't do anything
Jacksonville, did you remove the knock-out for the drain on the disposer? Use a screw driver and punch it out. Let us know if that did the trick..Catriver..post back.
Nov 22, 2006 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore 15129 Built-in Dishwasher Logo
189 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
