Question about Compaq Armada M700 Notebook
Compaq M700 Ram Upgrade the second
Hi there again I have another Question, somebody told me i can place one 500MB 133MHz sd-ddr SO_DIMM instead of two 256MB Ram Sticks inside Armada M700. Anyone knows if it is true i can use 512MB Ram? Any Help would be appreciated, thank you!
    President:
  • 2,961 Answers
I can find no spec on this but,if your notebook can take upt 576MB of memory, i would expect 2 x 256MB to be the max, as installing 1 x 512MB would be doubling the capacity allowed by one module slot.
Posted on Oct 01, 2007
SOURCE:
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
MS 6368 VER 5 MEMORY
It takes SD Ram, Which is no longer available. Below is the lonk to the Specs.
Link:
Mar 09, 2012 | Computers & Internet
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
I have 512 sd ram but i another 128,128 sd ram do included but its not working how can i solves this problem
The D815EEA2 motherboard only supports 512MB RAM maximum - I'm afraid there is no way to add more to it.
From Intel's description of the model:
Intel 815 Memory: Three 133MHz SDRAM DIMM sockets. Supports a maximum 512MB of 133MHz SDRAM
Aug 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Ram upgrade capability
Simply, yes you can. just open the case and put in the new boards. you can buy higher spec. memory(as long as the pins are the same number)
I.E. ddr-sdram boards will fit and as long as the speed is the same (132.8 Mhz) or higher.
I changed from 133Mhz to 333Mhz and the performance was much improved.
The PC3200 is the important bit, should be the same.
after you change the memory ,try running disc clean up in "start, all programs, accessories, disc clean up" this will also speed things up as well as de-fragmennting your drive(s)
May 02, 2009 | Computers & Internet
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
Ram Upgrade T20 and T22
hi you can try memorystock.com also i can order your ram and send it to you with a warranty I own a repair shop let me know what you want to do try memorystock.com
Oct 01, 2007 | IBM ThinkPad T22 2647 Notebook
you may struggle to find 100MHZ ram, but 133MHZ should be backward compatable, if you go to crucial.com, it should give you the alternatives you can fit http://www.crucial.com/
Oct 01, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
