Question about Logitech Marble Mouse Trackball
Doesn´t work with pro/engineer (panning an zomming)
  • 4,655 Answers
 love this trackball mouse, yet they are very sensitive to wear and trash that causes them to fail. Wal-Mart sells great ones like the Logitech LX3 optical mouse that are not as sensitive and have more features
Posted on Oct 22, 2007
How to put a oil pan gasket on a 1995 Suzuki 4x4 sidekick
It does not require a gasket and highly not recommended.Remove oil pan clean ,and reapply permatex black or gray sealant , install and torque to spec
Nov 04, 2013 | 1995 Geo Tracker
I took my 2001 Kia Sportage to the dealership for all new belts and a new oil pan. 60 miles later pullie froze blown head, no oil in upper engine? could their repair cause this???
Timing Belt Replacement & No new water pump & No new
idler pulleys ----while in there?
If the pulley's seize & belt comes off & if it is an interference
engine --- you can kiss the valves & most likely the heads goodby
The Water Pump can do the same thing,wobble or seize
Why a new Oil Pan, run over something?
What belts?
Why the oil pan?
Would like more detail
Don't think their that incompetent, but who knows
who was put on the job
I only recommend a dealer for warranty work,NEVER
anything else,UNLESS your local shop doesn't have or
want to do updates,then the dealer.
Anyone with a scan tool can buy the flash program module
& a one day ,three day,one month etc subscription for updates
to the PCM (computer)
Oct 05, 2012 | Kia Sportage Cars & Trucks
How to remove Search Safer Chatzum virus?
start up in safe mode with networking, then try to run malwarebytes as antivirus programs are virtually useless this day in age. If that doesn't catch it try hitman pro and after it is removed run ccleaner to fix the registry. If all of that doesn't pan out you need to do a full wipe/reinstall of the OS on the HDD
Aug 25, 2012 | Toshiba Satellite P105-S6197 Laptop
My windows xp pro product key doesn't work n
doesn't work how? when installing or there's an error message?
and did you buy an original windows xp? if so,you can contact microsoft for an alternative solution
Aug 22, 2012 | Computers & Internet
Zom macet, lcd bloor muncul reset button switch What's your problem?
Go to busytrade,be busy your trade.
Welcome busytrade,believe you come back with fruitful results!
welcome to visit to have a happy shopping journey!
May 09, 2012 | Panasonic NV-MD10000 Camcorder
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
I tried to drain my oil on my 2003 fxstdi from a plug on the bottom of the engine pan on brake side of bike. I of course learned this is NOT the right plug. The bike is supposed to be drained from the oil...
Hello and welcome to FixYa!
Oil spilled out on the bolt you removed? Hope to know more. It can be just a pan bolt that secures the oil pan. Just put it back and don't you worry. It will not harm your bike.
Hope this helps and thank you for using FixYa! Have a good one!
Jul 17, 2011 | 2003 Harley Davidson FXSTDI Softail Deuce
Mms application for iphone a1203, how can i get it?
Hi georeamarn,
In order to be able to send MMS from your iPhone, you need to contact your phone service provider. Some providers allow this possibility, some don't. In case you provider does not offer the possibility to send MMS using iPhone, you can use the official iPhone Mail Application through which you can send pictures to your email contacts (assuming that you want to use MMS to send pictures only). If you use chat clients such as Meebo or Ebuddy pro, you can also send pictures.
Hope this helps,
Jan 28, 2011 | Apple iPhone Smartphone
I need to replace the oil pan gasket on a 03 dodge ran 1500 2x4 with the 4.7 do I just unscrew it and take the gasket out put the new one in and screw it back together or is there more
Oil Pan - Removal & Installation3.7L, 4.7L And 5.7L Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine oil.
  3. Attach an engine crane.
  4. Loosen, but don-t remove, the left and right mount through-bolts.
  5. Remove or disconnect the following:
    Negative battery cable Structural cover Front crossmember
  6. Raise the engine just enough for clearance.
  7. Remove or disconnect the following:
    NOTE Don-t pry on the pan. The gasket is integral with the windage tray, and doesn-t come out with the pan.
    NOTE The double ended studs must be installed in their original locations.
    Pan bolts and studs Pan
To install:
  1. Install or connect the following:
    Oil pan gasket Oil pan. Tighten the bolts, in sequence, to 105 inch lbs. (12 Nm). Front crossmember Structural cover Negative battery cable
  2. Fill the crankcase to the proper level with engine oil.
  3. Start the engine and check for leaks.
    Fig. Oil pan bolt torque sequence-3.7L engine
    Fig. Oil pan mounting bolt tightening sequence-4.7L engine
    Fig. Oil pan alignment dowel placement-3.9L engine shown
Hope helped; TY for using Fixya (remember comment and rated this post).
Apr 14, 2010 | Dodge Ram 1500 Cars & Trucks
The Marble Mouse doesn't work with Pro/Engineer.
Hi Dose it work for any other 3D programs if so i think that you may need to add drivers from you mouse in relation to Pro/Engineerd projects
Oct 01, 2007 | Logitech Marble Mouse PS2/USB MSLO904360
Logitech Marble Mouse Trackball Logo
278 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
