Question about NEC Lands Phones
NEC Aspire Phone
I am trying to get back to the setting that when I receive a call from an internal extension, they can just talk to me. Right now it is ringing the phone instead of turning on the speaker phone.
  • 3 Answers
Press the CALL 1 key and dial 821. That will change it back.
Posted on Oct 01, 2010
When calling voicemail I receive a message after entering my access code that states "I'm sorry, I can't talk to you right now"
this means the voicemail card is full. look at all extensions mailboxes or a general message mailbox and delete all the messages and try again. If it is no good still you will need to get in the admin mailbox and change your mailbox to allow messages.
Apr 05, 2016 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
Need to reset nec phone
Easiest way to reset the phone is to unplug it then plug it back in. If you are talking about resetting the voicemail associated with the phone extension, that's a little more involved.If you need the voice mail reset, you need to have the voice mail administrator (typically the receptionist) go into his/her voice mail and choose the MGR option if using the display "softkeys" and follow the prompts to reset the users security code or voice mail acct. If softkeys aren't available, follow the voice prompts to "system manager" and either delete the security code or reset the extensions voice mail entirely.
Jan 19, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do. -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
I can hear the on hold message when the receiver is on the hook...
You can try pressing the feature key and then dialing 26. This is used to set background music on the extension when the phone is at rest. It also turns it off. This is on the dtu16 phones. Here is a link that has most of the user manuals for NEC phones. you should be able to find your manual here.
Oct 06, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Nec aspire phone
One of our extensions says it is on hold (Green Light keeps flashing) but we are unable to diconnect.
Jul 21, 2008 | NEC 80570 Telephone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
Internal intercom
If the person you are trying to reach is speaking to another internal extension, none of the outside lines will show in use. If their phone is not Call-Forwarded to any other extension (i.e. second extension or VM), you will get a busy.
Feb 06, 2008 | NEC Electra Professional ETW-16DC-2
Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
285 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
