Question about Cambridge Audio Azur 540R Receiver
Sonobuoy deplotyment Hi, I am trying to set up a transmitter-receiver system to record underwater sounds. All I have so far is a heap of old LOFAR sonobuoys (4 types: SSQ906, 981, 937A and 905) and I don't even know what signal (frequency) range the hydrophone covers/ VHF transmitter transmits, whether it is analog/digi signal that gets transmitted and what freq. range the aerial has got to be cut for. Another issue is the system's set-up- which is something I know nothing about and there is limited published information available. Thus I'd be most grateful for advice and comments on what I thought made sense and would work; I reckon ICOM PCR-1500 receiver, which records the raw data (?) straight to a laptop hard drive (?) seems to cover a wide freq range would be a good choice of a receiver (do i need a super-high spec sound card for this?). A remote aerial would aid in maximizing the detection range. The aerial would need to be connected to receiver via an aerial wire (?)and the aerial also has a pre-amp (where?). any guidance will be much appreciated. best regards, l.
I am trying to tune my laptop into receiving sound from a hydrophone listening device
Posted on Dec 19, 2008
  • Anonymous Dec 19, 2008
    I am trying to tune my laptop into receiving sound from a hydrophone listening device for cetaceans
You should check out the web site of thales or Ultra for information about both frequencies (Radio and hydrophone).
and you should check the frequency setting option, they all have it.
here is a link that will tell you the Freq. http://www.ultra-scs.com/pdfs/pdf_sonobuoy.pdf
Posted on Sep 28, 2008
SOURCE:
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
I have wireless speakers and the transmitter stopped working. Nothing happens when you plug it in--??? It's only a month old. AW872
Hi I also post in here , so that you can let me know how it goes.
Try unplugging the transmitter from power adapter, if it also has batteries remove them. Also unplug transmitter audio cable.
Then remove batteries/unplug adapters from speakers.
Wait few minutes and reconnect the system.
This is a proper hard reset, and can fix minor problems.
If when you re connect the transmitter does not glow, or you do not have sound on one or both channels then there is a fault.
Check the transmitter audio cable, a short in there can cause troubles.
If you find no problems , then unit is defective, as it is under warranty contact Acoustic Research to validate the warranty here and get the transmitter or the whole set replaced.
http://www.acoustic-research.com/homedecor/HomeDecorInfo.do?ACTION_TYPE_ID=ACTION_TYPE_CONTACT_INFO
Feb 13, 2009 | Audio Players & Recorders
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
I cant figure out how to record off the TV or VCR
Hi, you should setup analogue in function.
Page 93 on user's manual.
After that press REC PAUSE on camcorder and start your VCR or underwater camera.
Nov 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Recording From Underwater Camera
I have a gs11EB. I don't it's possible to record into this camea from an external source?????
Jul 03, 2008 | Panasonic NV-GS11B Mini DV Digital...
Onkyo TX-SR504 - Sound problem
Ooops, that did not work.  OK try  http://www.retrevo.com/s/Onkyo-TX-SR503-Receivers-review-manual/id/365ag216/t/1-2/  for download of manual in .pdf form, and English too!   Hope this helps.  Cheers,   Chris  :)
May 05, 2007 | Onkyo TX-SR503 Receiver
Cambridge Audio Azur 540R Receiver Logo
162 people viewed this question
Top Cambridge Audio Players & Recorders Experts
Eric Rotmil
Eric Rotmil
Don Hart
Franco Dosil
Franco Dosil
Are you a Cambridge Audio Player and Recorder Expert? Answer questions, earn points and help others
