Question about Canon BubbleJet i560 InkJet Printer
MY HP psc 1310 is printing out blank sheets of paper; the lights on top panel seem fine, but there is no green light shining on front....the orange one that appears when error is not lit. Can't imagine both cartridges running out of ink at same time. And if you unplug and replug it normally a test print sheet appears....not any more. Is there a scanner eye that can burn out?
    Problem Solver:
  • 22 Answers
Some printers deny service even if there is only 1 cartrige empty.
Posted on Sep 03, 2017
SOURCE:
SOURCE: Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
Posted on May 08, 2008
rapanSF
  • 150 Answers
SOURCE: Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Posted on Nov 06, 2008
vswright
  • 84 Answers
SOURCE: The printer is printing blank sheet
Hello Shirelle,
Make sure there is nothing covering the jets on the cartridge. Also how long has it been laying around? it might have dried out, and/or expired. On new printers the cartridges have expirations and it will not use them after a certain amount of time. Also try a printer self cleaning and see if that does anything. If none of that works, it might be the printer. - Vincent
Posted on Nov 23, 2008
pineworks
  • 4345 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
canontech
  • 1219 Answers
SOURCE: COPIES PAPER BUT PRINTS BLANK SHEETS
You probably haveing poblems with laser shuter. call service
Posted on Feb 15, 2010
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
Replaced black ink but still can't print. Light o...
At the lower back of the printer, there is a panel. Open it and if there's a paper stuck, pull down the two green locks on both sides to pull out the paper. Push the green locks upwards and close the panel. Then open and close the top panel of the printer to 'refresh' printing.
May 21, 2010 | HP LaserJet 2550L Printer
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP 1310 series
I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
Sep 04, 2007 | HP PSC 2210xi All-In-One InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
42 people viewed this question
Clive
Clive
old marine
old marine
