Question about OKIFAX 2600 Fax
Message confirmation page
I do not have an manual and I need to set up machine to produce a message confirmation after each fax. How do I do that.
You can download a copy of the manual from the OKI website:
http://www.oki.co.uk/binaryData/2299/2600uGB.pdf
Posted on Nov 05, 2007
SOURCE:
Cannot recieve faxes more than 2 pages long. Message Communications error 232
The device has a communication malfunction.
possible diagnostics to be performed
1. The communication lines or phone connectivities are malfunct, consider unplugging each modem properly reconnecting taking keen observation of jack areas on the fax machine, and the external areas on the router units splitting the signals.
2. The fax machine paper feed system is clogged possible inspection of the tray areas making sure to unclog stuck paper.
a. The fax machines provides an image measurable in laser signals required to produce results immediately. Any delay in the signals or data when arrives in fax machine could cause incomplete imprint
3. The fax machine could have many messages queue causing delay malfunctions.
a. The type of signal splitter available at the location could cause to delay, where a delay excapes signal recognition on the paper only producing a few data records
important notes
1. consider acquiring a fax consigment at a time
2. consider distributing fax loads to another infrustruction
Error 232 is a connectivity message
1. possibly caused by accidentally unplugging a connection and reconnecting while fax machine was powered on.
2. possibly caused by connecting another fax machine to the set up of infrusture without performing system restore to intergrate all devices connected to the network.
3.possibly also caused by a computer program malfunction.
a. consider reinstalling the programs that connect the fax machine; for example access the computer networking infrusture icons located in the control panel area of the computer programs list bar to perform networking diagnostics for the fax machine
instruction s of performing a fax network reinstallation
1.The networks on the computer housing every additional peripheral device like faxes all share with printers, game consules and several recognisable within the computer server or mainframe computer. A wireless connectivy of several connection compromised the intergrity of some devices.
The response to the problem in computer sending a message with a number to make possible locating the by expert technictians.
2. Several peripherals connected to the computer server produces error messages readable where huge numbers being sysbols of easy problems only on a computer performing several resposnibilties, in which sitaution of faxes, the error 232 could be the number of faxe assigments failures, or number faxes waiting to be completed.
Dec 02, 2010 | Office Equipment & Supplies
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
WANT TO ATTACH A MESSAGE MACHINE
The message machine needs to be set to answer 1 ring before the fax is set to answer. When the phone rings the fax starts listening even when the answer machine picks up. If the fax hears fax tones it will receive the fax and if no tones the answer machine will take a message.
Jan 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
OKIFAX 2600 Fax Logo
150 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
