Question about Car Audio & Video
Power not turning on no led activity is it possible that the processor is defect? have no servmanual so its very difficult some measurement values would be helpful regards raikkonen
  • Anonymous Jan 29, 2008
    i had this amp hooked up before in my truck.. thought i was selling my truck so i removed the amp. when i hooked it back up, no lights, nothing. LED light is not on. and no sound coming from sub. one thing im not sure of, i didnt install my aftermarket deck before, i had it done. this time i reinstalled it myself. the only question i have, the wire that is connected to the amp the remote/power ant. wire, im positive its connected correctly to my deck, could that have anything to do with no power going to the amp?
Yes it really help me to get my system running thank u my buddy.
Posted on Sep 11, 2008
  • 65 Answers
You can short the remote turn on to the +12V and see if the amp comes on that way. If not, either the amp is hooked up wrong, or it's faulty. Let me know and be sure to leave good feedback or I don't get paid.
Posted on Oct 03, 2007
I have an LG 47LN-5400-UA when I turn the power on the LED blink and I have audio, when I measure the voltage output to the led on power supply no voltage. Please advice
LG 47LN5400 no backlight repair Part 1
Have you tried some Youtube suggestions about this model ? LG is a special brand most difficult to do something without an service manual , control for bad solderings (special on active components with heatsinks) , bad fitted fcc sheets connectors power supply In safety mode because of an failure somwhere.
Oct 31, 2017 | LG Televison & Video
Error sign when turning it on. New batteries where installed
Possible that the LOAD CELLS are defective. Please check the main power and the feed to the processor and if the voltage are correct, then check for mechnical jamming of the tray . If there is no there observation , the fault can be the load cells. Estimate the cost of new cells, if possible get a trail piece for confirmation.
Sep 23, 2011 | RTO Us Balance Usx-500 Digital Scale
My Sansui 32" Model LCD32hbw got stuck with the
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Sep 03, 2011 | Sansui 32" TV
Wont measure distance
Must see if the battery is in correct polarity and is set right . If power comes without any measurement, thenit is possible that the laser is not active , the beam is not readback , the processing is faulty for the return signal.
Might have the main board processor faulty.
Sep 24, 2010 | Nikon Archer's Choice Laser Rangefinder
Dell inspiron 6400 problems switching on power After switch on the poweer button .. One led is staying on and other two led is blinking after sometime all led light gone off.. Please advice me to...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | Computers & Internet
My Acer make Laptop model: aspire 4520 not power on , power led and dvd led flashes at the same time and screen blank.
Sep 11, 2010 | Acer Aspire 4520-5582 Notebook
Have power..no display..power led blink several times and then goes off
4. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
Xerox Phaser 5500dn will not power up when turned
The problem turned out to be a defective IMAGE PROCESSOR BOARD.
Dec 15, 2009 | Xerox Phaser 5500/YB Laser Printer
Unbalanced LEDs> amplification problem, or mere graphic drop out?
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Apr 12, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Power to laptop , but hard drive activity light
possibly a bad processor.I built two that did the same thing,,,already replaced processor in one and it works fine now
Apr 11, 2008 | Toshiba Satellite A55-S106 Notebook
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
