Question about IBM ThinkPad T22 2647 Notebook
Ram Upgrade T20 and T22
Hi there I want to Buy new Ram for 2 IBM Laptops, one is a T20 and the other is T22 and i am not sure wheter i can Buy PC 133MHz SO-Ram for those Laptops instead of normal 100MHz SD-Ram. I would like to Buy twice 2 x 256MB 133MHz SD-Ram for both Laptops. Any advice would be appreciated, Thank you!
  • 4 Answers
Hi you can try memorystock.com also i can order your ram and send it to you with a warranty I own a repair shop let me know what you want to do try memorystock.com
Posted on Oct 01, 2007
6ya staff
SOURCE:
Need info about series
The type of drive is IDE and 2.5- Inch for all those models.
T20, T21, T22, T23 --- 2647 all use the same IDE type of drive.
These you can buy for example in ebay. Search for laptop hdd ide 2.5inch or similar.
Jul 01, 2012 | IBM ThinkPad T40 2373 Notebook
No sound device found on ibm thinkpad 2647 l
FIRST STEP:
You can download the sound drivers on this website: http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4ENRG5
This Package provides the audio driver for OS/2 users.
The Audio Features Package enables the audio function of the following ThinkPad computers:
- ThinkPad 600X
- ThinkPad T20, T21, T22
NOTES: See the Additional Information section below for instructions on what''s new in this release and how to install this driver.
This program is language independent and can be used with any language system.
c.gif c.gif File details c.gif Version: 3.10 Release Date: 2001/08/16 c.gif File link File size File description c.gif aftpitos.exe 434,478 version 3.10 - Audio driver III Diskette for OS/2
aftpitos.txt 3,011 README for version 3.10 - Audio driver III Diskette for OS/2
c.gif Additional information c.gif Click here for instructions and limitations on downloading and creating the diskette.
This Additional Information field contains the following sections:
I. Summary of changes
II. Installation instructions
III. Determining which version is installed
version 3.05
- (New) Support for ThinkPad 600X
version 3.06
- (New) Support for ThinkPad T20
- (Fix) No sound after MIDI file playback.
- (New) Support for ThinkPad T21
version 3.08
- (New) Support for ThinkPad T22
- (Fix) Hang up during Boot.
version 3.10
  1. To install device support, extract the package to a directory on the hard disk drive.
  2. Start the Multimedia Application Install program:
    • On the OS/2 desktop double click the OS/2 System folder, click the System Setup folder, click Install/Remove, then click Multimedia installation program, or
    • Alternatively, you can execute MINSTALL from an OS/2 command prompt or browse the installation diskette with the OS/2 drives utility and double-click the icon for install.cmd.
  3. Once you are in the multimedia installation program, select the drive and subdirectory you copied the driver to. The installation program will show Crystal Audio PCI (Pre-selected)
  4. Click the install button to proceed with the installation. Read and follow the instructions provided by the installation program.
  5. After you complete the installation, restart the system.
NOTE: To remove audio and MIDI drivers, select zero devices when prompted for the number of devices to install. Selectable choices are 0 and 1.
Check the following files' size.
Directory Files Version
3.06
Version
3.08
Version
3.10
C:\OS2\BOOT CWCSPUD.SYS 169181 171516 169391 CWCMMPM.SYS 45904 45900 52620
IF the FIRST step did not work then,
Contact the IBM Support hotline for assistance on Hardware configuration of the system at 800-426-7378
Feb 15, 2011 | IBM ThinkPad T22 2647 Notebook
Processor and Disk space
The biggest processor available for the T20 is 1ghz. Be sure when replacing the processor that you get an IBM 133mhz processor. The memory is 1g max, the machine will hold two 512mb chips, and be sure that it's PC133 memory. You can put up to a 120g hard drive in the machine, be sure the hard drive is an IDE 4200rpm drive. These are the specs for the T20, and the maximum size this machine will hold. You can go to this max or anyplace in between.
Aug 27, 2008 | IBM ThinkPad T20 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
Ibm thinkpad 2647
Your limited with the T20 series, the biggest you can go is 1ghz. Try the Pentium M chip, make sure that it's the same mhz (frequency) that's in it now, the board frequency matches the processor frequency. (either a 100 mhz or 133 mhz, you can tell by what memory it uses PC100 or PC133)
Jun 09, 2008 | IBM ThinkPad T22 2647 Notebook
Ibm thinkpad 2647 screen blackout
could you see anything on the screen ??? if so but no light on screen then it can be inverter, in can be voltage or motherboard problem.Best is to have somebody qualify to fix for you.
takecare.
Apr 06, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 how to disassemble
Here is the link to the ftp: location for the maintenance manual:
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf
This applies to IBM ThinkPad T20, T21, T22, and T23 series machines.
Mar 08, 2008 | IBM ThinkPad T20 2647 Notebook
CPU Upgrade Help
I'm pretty sure it's socket 370.
Oct 01, 2007 | IBM ThinkPad T22 2647 Notebook
Compaq M700 Ram Upgrade
you may struggle to find 100MHZ ram, but 133MHZ should be backward compatable, if you go to crucial.com, it should give you the alternatives you can fit http://www.crucial.com/
Oct 01, 2007 | Compaq Armada M700 Notebook
CPU Upgrade
I think its an intel P3 socket 370.
IBM ThinkPad T22 2647 Notebook Logo
87 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
