Question about Acer Aspire™ T180 PC Desktop
VGA? Is there anywhere I can get the hold of a mobo map? Ive recently had to reset the BIOS but now everytime the system starts up Im gettin the old 1 long 2 short on the POST. Only thing is, I bought this PC second hand with no manuals, so cant see if theres any way of disabling the VGA part of the board. Ive already tried starting it up with a flash disk but still get the same results. If anyone could throw me a bone on this one it would be well appreciated. Cheers
  • John Nicholl Oct 01, 2007
    its the onboard one thats the problem. Will it pick up a VGA card over the on board for the POST?
  • 661 Answers
Connect to the VGA on board, then in bios you can change the setting for VGA, you should set it to "AGP first" or "AGP Primary" This will mean that it will look to the AGP slot first.. hope this helps
Posted on Oct 01, 2007
How can i rebot my compaq presario CQ57 with a black screen
with the huge battery removed? why not do that FIRST FIRST?
100% black all the time,, not even text here, ever.
not even using a flash light? pointed at the screen,?
but now all screens are dead.
ive no idea at all what is plugged in here, its all over the map.
Laptop screen
VGA screen (has hot key , if not used the port is dead, RTM?)
projector.? huh? (yes, ive used them for years)
did you read the users guide yet, if not why?
you posted anon, 2 times. now? why?
so the PC is bad. (check)
so you are asking how to diagnose a PC with no tools ?
well if you make a BOOT CD, for 10cents and boot to linux live CD
if the screen is dead the the PC is dead. end story
  1. remove main Battery, bingo.
  2. replace power pack, it costs $15, we use a voltmeter you dont have.
  3. The PC is overheated fans dead or packed in lint, as all are this old, ALL ARE. or the heat sink is failing, only a tech can fix this.
  4. Its old, it will fail as all old PC's do, BAD memory, try 1 stick at a time.? finding new sticks are ******* old PC , super hard.
  5. BAD CMOS coin cell causing RTC to go nuts BIOS settings same. replace the coin now. but usually it never kills the screen, but never seen a good coin this old so.... there you go...
  6. BAD mobo. The MOBO has lots of chips, cpu, GPU, Glue logic and regulators.
For sure the GPU chip is upset, why we dont know. takes lost of testing and lacking spare parts is many times impossible to cure.
Apr 27, 2017 | Compaq Computers & Internet
Computer restarts over and over @ bios screen
you may try resetting bios by taking off the small battery on motherboard for few sec, also if you got manual for your motherboard there may be way to reset bios sticking together 2 pins for couple of sec. Is radiator fan working? if no there's solution.
Feb 11, 2014 | Gigabyte GA-M68MT-S2, AM3, nForce 630a,...
HP Boot problem
a1540n PC Desktop fails to boot unstated OS....
a very obsolete PC, in fact HP retired, support.
no problem really but makes getting books on it harder... facts...
  1. so did you make sure all fans work? and stay on,
  2. does the DVD drive eject button work
  3. does the keyboard caps/num/scroll locks LED toggle, when pressed
  4. does BIOS work with 1 DDR2 RAM stick (1 by 1) not 2 at once
  5. do the fans all work , up to 3?
  6. Does the F1 key work, hit fast at power on button, in 1-3seconds? immediatay after power on.
  7. did the screen show Hit F1 to enter HP setup? if yes did you?
  8. any PCI expanisin cars in the PCI slots, remove them?
  9. remove DVD and HDD cables, see if BIOS works.
  10. CPU fan Heat sink fins not packed in lent, as all are, clean it with Can-o-air?
  11. test the PSU? (ask)
The goal is BIOS screens, first. first things are first.
carbon dating retired PCs (hp zero support now)
is not easy. and is key to learning what BIOS is there (a pain)
the date you bought this PC is not important , the date it was made maters only....
standing here, i cant do that, id need to do hands on inspection
old AMD Athlon 64 X2
says ,,,,DDR2 SDRAM 2x1g it says, remove one?
NVIDIA GeForce 6150 LE TurboCache supporting 256MB
integrated, VGA.... no card. if it has a card for VGA remove it to test system using integrated VGA jack on MOBO
best i can tell, 99% off all review on pc have TIME STAMP(DATE)
but one review said it had norton 2006
so we know that one is 2006 and is over 10years old.
maybe 12 years old.. the dvd drive has date code, there in clear english, dates, if it says 2005 , there it is. other HP codes
in the PC also date the PC.
i looked up your ASUS mobo and they says its
The current bios is 3.07 phoenix-award bios.
Even ASUS dont have data on A8m2n mobos. now.
huge list of keys on PHoenix bios.
my guess is F1 or F10 is the BIOS hot key
remember HP ordered Phoenix bios under contract and HP
can in fact dictate hot keys... so HP wins here.
find the answer to this is hard. (no HP books)
hint 1: the coin cell battery can be dead, replace it on the mobo
life spans 3 -5years possible most makers top life is 7.
the goal is here, if this works we test the HDD next.
see?
its just 2 goals, BIOS, below
then getting the HDD working and last the unstated OS working.
Jul 15, 2017 | HP Pavilion a1540n PC Desktop
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Gigabyte onboard vga is not default... no pci card
What you can do here is remove the Battery on your mobo. This will reset the CMOS and then you should be able to access your CMOS as usual. :)
Dec 25, 2007 | Intel Motherboard
System don't Reboot
Assuming you have already installed the AGP driver for the motherboard, you will have to start the pc in safe mode (F8) on boot up, to start in VGA mode only and see if the graphics are ok. If it boots into VGA mode then the card itself is ok, but the card driver and agp motherboard driver, if not already; will need to be installed at this point because im assuming you were not able as you were getting the fault on screen.
May 01, 2007 | Pine Technology TLSI211004 Motherboard
Acer Aspire™ T180 PC Desktop Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
