Question about Sony PlayStation 2 (PS2) Console
L3 and R3 problems
How do I activate L3 and R3 on ps2 analog controller. It only has options for L2 and R2
    Problem Solver:
  • 10 Answers
Just click the two analog sticks for L3 & R3
Posted on Oct 07, 2007
The analogue on the right is r3 push it down do the same with the left that is l3
Posted on Oct 03, 2007
L3 and R3 r yr analog buttons just simply push down on them
  • Anonymous Oct 03, 2007
    if any1 has a problem with the game yu-gi-oh dulists of the roses ask me i have a gate gardian standard.
SOURCE:
How to connect logitech g27 paddles to ps3
Plug the device into your console.
In a racing game, Go to options, Logitech Racing Wheels, Steering Settings. Steering type=simulation. Power-Assisted Steering=Off. Force Feedback is up to you (I use 8).
Then, exit Steering Settings and scroll right. The G25 is not listed in the options menu. Use the DFP to map the controls. Paddle shifters are L1 and R1. Buttons on wheel are L2 and R2. D-pad is same as DS3, as are the four black buttons above it. The four red buttons are (from left to right), L3, Select, Start, R3. The forward/back on the sequential shifter can also be mapped if you choose to do so. Hope this helps.
Dec 24, 2011 | Logitech G27 Racing Wheel
WHERE CAN I DOWNLOAD A COPY OF THE NASCAR 07 INSTUCTION MANUAL?
I couldn't find a downloadable copy but got a hand written one:
NASCAR 07
RACING CONTROLS
Directional Buttons Steering
X Button Share Draft
Triangle Button Reverse
Square Button Intimidator
Circle Button Change View
L2 Button Brake
L1 Button Shift Down
R2 Button Accelerate
R1 Button Shift Up
Start Button Pause
Select Button Toggle Mirror
Left analog stick (L3 Button when pressed down) Steering
Right analog stick (R3 Button when pressed down) Team Communicator
Jul 08, 2011 | Electronic Arts Nascar® 07 for PlayStation...
It says to press R3 and L3 to use the Rage of Titans. But the controller has only up to R2 and L2 so what should I do.
The L3 and R3 buttons are actually there, you just have to push the controller sticks down towards the controller itself. Put your thumb on either stick, and press instead of moving. That will get you back into the killing mode. Good luck with God of War. Cool game, lots of moves to learn, chests to find, and mythical monsters to slay...what could be better? ;)
Hope that clears up your problem.
Cheers from NZ
May 23, 2011 | Video Game Consoles & Games
What is L2,L3,R2,R3
the button is dirty,
open and clen it
Jan 26, 2011 | Sony PlayStation Portable (PSP) Console
Newbie here. Is there somewhere I can see what button is number 1, what button is number 6, and so on?
the left button on the left side is 1 lower key is 2 right key is 3 top key is 4 then it goes 5 and 6 for l1 and r1 7-8 for l2 and r2 9-10 for select and start 11-12 for the l3 - r3 This was found just testing my own controller so i can assume it is the same for you. Thanks, Midwest-tek
Aug 31, 2010 | Sony PS2 Dual Shock 2 Controller...
Don't know where y button is on my psp2
I think someone is messing with you, for there are x,o, square, and triangle buttons, plus L1, L2, R1 and R2, and then select, start and then R3 and L3 but there is no,i say no y.there are y buttons only in xbox 360 if this helped you or you think i spent some time to answer your question rate helpful thanks
Sep 27, 2009 | Sony PlayStation 2 (PS2) Console
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Cheats of complete characters of naruto3 in PS2
unfortunately i don't have a cheat to unlock everyone, but this is pretty close.
Unlock everybody but Hanabi and 4th Hokage
At the main menu do the following:
1. Hold R1+R2 then press Square, Triangle, Square, Triangle
2. Hold L1+L2 then press right, up, right, up
3. Press L3+R3 at the same time.
You will hear a sound to confirm code entry. This will unlock everybody but Hyuuga Hanabi and Yondaime (4th Hokage).
Feb 02, 2009 | Sony PlayStation 2 (PS2) Console
Can't connect nerf ps2 controller to its receiver.
the L3 button is Left thumstick pressed inward
R3 is right thumstick pressed inward ;P
pls rate .
Dec 16, 2008 | Pelikan Performance Designed Products...
Tht sims bustin out game playstation 2
Hi clinnane,
Try these>
During game-play press pause and enter the following codes. The Gnome cheat
Must be entered first for these cheats to work
Gnome Cheat:
R2, L1, R1, L2, Left, Circle
Note: If a cheat is not allowed a Gnome will appear on the Sim's property to
Signify this. You can click this Gnome for money.
Unlock All Socials:
L1, R1, Down, X, L3, R3
Unlock Team Photos:
L3, R3, R1, R2
Unlock All Skins:
L1, R2, X, Circle, Up, Down
Fill Motives:
L2, R1, Left, Circle, Up
Unlock All Locations:
R2, R3, L3, L2, R1, L1
Unlock All Objects:
L2, R2, UP, Triangle, L3 Happy gaming :)
Sep 23, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
265 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
