Just got some new coffee beans and ground it up and prepared the machine a Delonghi EC330. The coffee dripped out very very slowly. So cleaned the holes in the spout, cleaned the espresso boiler outlet and pressed the tank lightly to open the valve at the bottom. None of these worked. About to try putting in a bit of vinegar in with the water to see if that clears it out. Any more suggestions? Only had the machine since Xmas but it is used everyday.
Machine is still under warranty. Go to your instruction manual and call Delonghi about this problem. They will replace unit for shipping charges only. Tell them problem you are having, sometimes they tell you how to solve problem.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
I have the Keurig B30. It isn't brewing the entire cup of coffee--only about half, with water left...
(More)
I have the Keurig B30. It isn't brewing the entire cup of coffee--only about half, with water left in the resevoir. Thanks
When I run water through the Keurig, it works fine, but the moment I put in a coffee, it balks,...
(More)
When I run water through the Keurig, it works fine, but the moment I put in a coffee, it balks, sniggers and refuses to brew. I think there must be something wrong with the perforation -- as though it senses it cannot let water into the coffee to brew.
