Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv problem i have 47 inc panasonic raer projecter now the image have a blue and yellow shadow and also the words have a shadow some body told me the guns need to reline i dont know what to do can yoy help me please
  • jumano Oct 03, 2007
    thanks for the helpe i tried to set the converegence but did not work to change convergence ic*2 how can i do that is it apart i have to change how and from where i can get it thanks
  • sjs02hfx Nov 12, 2007
    I have the same blue and yellow shadow!!! It tried to adjust blue conv. center ones will align ok however the right and left ones will not... it seems the blue shadows/ghosts are predominantly on the left and right but not that apparent in the center... Can anyone help? thanks
    Problem Solver:
  • 8 Answers
Setting the doesn't require any parts. It's done with the remote control using menus. On that particular TV, press menu (action) scroll over until you get to the second option from the end. I don't remember what the heading is, but one of your options is convergence. Select it and use the right arrow key to begin setting it. Just follow the instructions on the screen. First you'll have to set both the red and the blue to match the green in the center. Use 0 to switch between red and blue. Then press menu (action) to continue. Now you can fine tune around the edges. Use the number keys on the remote to select the region of the screen, and again use 0 to switch between red and blue and try to line them up as closely to the green as possible.
When you're finished you should see a bright beautiful picture. These sets look very nice.
Posted on Oct 21, 2007
Seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Posted on Oct 03, 2007
SOURCE:
Red, green and blue shadows
have you tried to run auto convergence
Mar 08, 2013 | Panasonic PT-47WX49 47" Rear Projection...
The Panasonic mod# pt-47wx49e has started to have a blue and a yellow shadow on the right side of the screen. the rest of the screen is normal. The operating instructions give you diddle to on. Do you have...
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows or 3D colors pictures.The tv convergencce board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 10, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Picture now has alot of yellow and blue shadowing
Ur tv have convergence problems,it dead.Require 2 STK convergence ICS and some or all it resistors replaced on the convergence board.The shop will cost u $300-350 for parts and labors.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Blue and Yellow Shadows!! Help me
Have a qualified repair shop come have a look and give you an estimate. If it's the optical block it's probably not worth repair.
Sep 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PANASONIC V IS YELLOW AND BLUE WITH SHADOWS
you can get the convergence repair kit for that model at www.tvrepairworld.com thats the most likely cause of the problem. The kit comes with the parts and CD with instructions.
Sep 20, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
