PRINTING IMAGES ON CD'S/DVD'S - SMUDGES / i865
Hello from Australia. I have a Canon i865 printer and generally, I've been very happy with it. Yesterday I've had trouble with printing images on cd's or dvd's. It's surprising as I've never had problems. There's a simply a smudge of " C " shaped letters that are running down the image in a vertical fashion. These are cyan in colour. These smudges have nothing to do with the image as they should not be there. At best one or two copies have been acceptable but the brightness has gone as well. I have replaced most of the ink catridges but realize there's a small amount of ink left in the larger black ink toner. Also notice a small area of the tray upon inspection ( and after printing ) has a light residue of which you can wipe off. Useing Disc Cover Re to create my images and Label Print. Please help Sabojams
    Sergeant:
  • 279 Answers
After looking at a picture of the CD you were printing to, I see the problem. The printer is trying to print blue ink on the middle of the CD, where the hole is. The problem is, since there's a hole that ink is going through and getting onto the rollers in the printer. It's then transferring back to your media as it moves through the printer. It's C shaped because you're only printing on about half of the hole. There are two ways to fix this. Either put a round piece of tape over the hole to cover it (and thus the paper will be printed on), or change your image so it doesn't print to that part of the CD. I'd suggest the latter, as it will look neater when you're done.
Posted on Oct 02, 2007
SOURCE:
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
Printing directly onto CDs
I'm afraid that is not possible with the printer. You an do cd/dvd labels but you can't print directly onto a cd.
You would need a CD/DVD burner with a Light Scribe capability. You also need special CD/DVD's to use Light Scribe.
Thanks for using Fixya.
PS. Just for additional info, here is a link to support for your printer:
iP4200 Support
Mar 19, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Need canon i865 installtion disk
Go to the Canon WEB site to download the printer driver for your model printer.
Oct 20, 2009 | Canon Office Equipment & Supplies
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Want to dounload and install canon i865 printer do not have CD to do instalation
You can download all ur drivers and softwares that you have in ur cd from canon official website for i865 printers at here.
All you have to do is select ur OS and Language!!
Feb 02, 2009 | Computers & Internet
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon i865 misfeeds paper
Hi, i had the same problem. Solution: A small plastic part of my headset was fallen into it. I opened the printer and found it there. It blocked the paper. You can open the printer by pressing down all the plastic locks with a screwdriver (about 8). There is one under the Power Button, that you have to disengage first (2 screws). While the printer is open you can check what's wrong by printing a page and see what it does. Maybe cleaning some parts already helps.
Aug 25, 2008 | Office Equipment & Supplies
Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Feb 12, 2008 | Canon i860 InkJet Photo Printer
Open Questions:
Kodak Printer TeCh SuPpoRT pHoNe #@{+1*85526OOO64~^~} nUmBeR JA USA Inferior security at FIXYA and 6YA leave your financial and bankcard data and personal passwords at risk of being sold by cybercriminals in India. Toronto-based VerticalScope Inc. says six of the community websites it administers were hacked last month in the latest of a recent series of data breaches affecting Canadian online user information. The company says in an emailed statement an “unauthorized party” gained access to community member data for six of its websites on Oct. 17 and 21 and some of the data was disclosed online. It says the data did not include credit card or banking information but did include usernames, email addresses, encrypted passwords, user identifications, registration dates and IP addresses for websites including DIYchatroom com, PBnation com, HysterSisters com, ToyotaNation com, JeepForum com and WatchUSeek com. Alex Holden of Hold Security, LLC, says his American cybersecurity firm was able to intercept hackers’ attempts to sell data stolen from VerticalScope and tracked down screenshots containing current secure information to confirm the breaches had taken place. He says the attack was “rather sophomoric” and its success doesn’t reflect well on VerticalScope’s cybersecurity readiness, adding it’s unclear how many people had their confidential information stolen. VerticalScope, which is majority owned by TorStar Corp., says it has caused all of the passwords on the sites to expire and has notified affected users. It says the breach has been reported to the federal Privacy Commissioner, Toronto Police Service and the RCMP cybercrime unit. About 8,000 Canadians had personal information and, in some cases, credit card information, exposed in the massive Equifax cyberbreach that occurred in July but wasn’t reported until September.
Oct 15, 2019 | Kodak Office Equipment & Supplies
69 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
