Question about Intel Motherboard
MotherBoard problems My motherboard doesn't make a sound on startup, and i can't view.Even when i took out the Ram it doesn't beep.
  • Floyd Ntsuseng
    Floyd Ntsuseng Oct 02, 2007
    These computer was working fine before, it happened after a power failure.
    It does switch on , but the is beep sound and the monitor is just blank.
    You can see the motherboard is running, and oh i did check the CPU and the are no bent pins, and the four pin power cable is inserted
  • 94 Answers
Does the power led turn on your motherboard when you switch the power? There are so many things to do to troubleshoot your motherboard. Check if there is a small speaker connected mostly its connection is beside/near the I/O cable hooks. Check your video card, if you have a spare and working video card try to replace the one you are using now. Lastly check your power supply and try to replace it if you got a spare one.
Posted on Aug 01, 2009
  • 661 Answers
Check your CPU, it is possible that you bent a pin when trying to insert, also if P4 check you have the P4 (4-pin) power cable inserted. as the mobo will not work without it
Posted on Oct 01, 2007
  • Gareth Cockram
    Gareth Cockram Oct 04, 2007
    ah... you did not mention the power failure...
    when there are power failures, you can also get power "Spikes", These "spikes" can toast your system if you don't have a Surge protector (usually in the form of a 4-way gang plug with some special electronics inside) the surge protector will take the "hit" and your system should not get damaged.
    often power spikes can toast your memory, modems and graphics cards, and often kills your power supply.
    hopefully all that is wrong is that your power supply is not working any more, and needs to be checked/replaced, if you can borrow a psu to test your system you can prove whether your psu is Blown. (not providing the correct voltages over all lines)
    if this does not work, then try to diagnose by removing all of your PCI cards and drives, and swapping your VGA card to test (borrow if possible), if this fails then it is either the motherboard, the processor, or the Memory, or any combination of those three.
  • Gareth Cockram
    Buy a Surge protector if you do not have one
SOURCE:
P4VM890 - 3 long beeps
1) Son follow Anti-Static Procedures?
Ram Memory could be [email protected] now if not.
To include motherboard, processor, and graphics card; IF used.
2) All power cables attached to motherboard, AND tightly?
http://www.asrock.com/MB/overview.asp?Model=P4VM890
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
3) AMI BIOS 2.3.1
BIOS Beep Code - 3 Beeps
Indicates Ram Memory failure.
Cracked motherboard at ram memory slots, due to too much pressure being applied to motherboard, while in computer case?
Cracked motherboard at ram memory slots due to, user inadvertently had ram memory turned around backwards; and tried to install?
(Locating Notch was not lined up with Locating Lug, in ram memory slot)
4) We all get in a hurry sometimes, and make mistakes.
(Seen those commercials? Ha!)
Is there a 'stick' of ram memory in Slot 1? (DIMM 1)
That is the ram memory slot the Processor reads first.
5) I gotta' tell ya, Fred; I think we are dealing with a Static shock issue here, or cracked motherboard.
Was working, then ram memory removed/reinstalled; and now Not working.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Asrock P4VM890 Motherboard
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
It doesn't accept a memory ram upgrade. I had 512 MB and wanted to install 1 GB but the beeps started to sound.
The beeps are likely related to a memory issue on your motherboard when you boot up. This is usually caused by either getting a bad Stick of RAM, or the specs of the RAM are not compatible with your motherboard. Make sure that the specs of the new RAM is exactly the same as the specs of the old RAM. Each motherboard can only accept certain specifications of RAM. If you have additional questions feel free to leave a comment and I will get back to you on it.
Sep 13, 2011 | Dell N6381 Motherboard
Constant beep at startup
THIS BEEP SOUND INDICATE YOUR RAM/RAM SLOT PROBLEM
OPEN YOUR CPU AND REMOVE RAM
CLEAN YOUR RAM SLOT USING CLOTH
AND REINSERT YOUR RAM
T
PLEASE VOTE IF YOU SATISFAID
Dec 06, 2010 | AOpen AX34-U Motherboard
Beep codes and type of error. (beep codes before startup)
BEEP SOUND INDICATE RAM FAILURE/PROBLEM
1)REMOVE RAM AND CLEAN SLOTS AND INSERT IT
Nov 13, 2010 | Intel Motherboard
Memory problem on startup?
Well, according to your manual, Long beeps in a endless loop mean no DRAM was installed or detected. What type of RAM are you using? The problem is with your RAM only. if the frequency of your RAM doesn't matches your motharboard then it will not work. The frequency of RAM varies from 233MHz, 333MHz, 400MHz, 667MHz, 800MHz, 1033MHz etc.. and also it varies from motherboard to motherboard.
Thank you.....
Jan 29, 2009 | ASUS P4XP-X Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
