Question about BenQ FP757 Monitor
Color display issues with BenQ FP757 monitor
I had a white blank screen issue and sent my BenQ FP757 monitor in for service. It came back after a few days with a little problem. I just cant seem to get the standard combination of blue,red and green to set my monitor display to normal. Its either too red, or green or blue. I have tried using the sRGB option and also tried setting the R, G and B components to 50,50,50 too (as is on a colleagues monitor)but still cant get the optimum setup. Any suggestions?
  • Anonymous Mar 29, 2014
    I have BenQ GL2030 - LED monitor - 20" - 1600 x 900 - - GL2030. Installed new version of windows XP. Display setting doesn't have 1600 x 900 option .....what to do?
  • 220 Answers
Go to menu and try Recall all.
Also possible that panel is defective.
Posted on Mar 05, 2008
Monitor blue light comes on, the picture is on for a brief second but screen goes black, how do I fix this problem please.
I have had this problem before and had to contact the manufacturer. I was able to send them back and the manufacturer sent me a replacement. If your monitor is under warranty it should not cost you anything.
Mar 15, 2011 | BenQ FP757-12 17" Flat Panel LCD Monitor
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
No display
BenQ made a lot of monitors for Dell. You may want to look at Dell pictures.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 11, 2010 | BenQ FP757-v2 - 17" LCD Monitor
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further:
Mar 22, 2010 | BenQ FP71E 17" LCD Monitor
15 inch lcd monitor Benq Model Q5T3 has a blank screen has power but screen just black. Can let it sit for a while and sometimes it will stay on for a few minutes but goes black again Thanks
It could either be a driver issue on your system, or a problem with your video card. Turn off the computer, open the case, remove the video card, re-seat it in the slot securely, close up the system and power it back on. If the problem still happens, update the display adapter driver, if it still happens, try a different video card or monitor. You could even test your monitor by plugging it into a system that you know doesn't have this issue.
Feb 22, 2010 | BenQ Computers & Internet
The screen goes blank (white) for a few seconds and goes back on, and then does it again, irregularly about every 5-10 minutes. Help, anyone? Thanks!
To isolate this issue first find out whether notebook LCD display gone bad or not....... to do this connect the notebook to any external monitor with the help of VGA port which looks like a blue port...... determine whether issue is with LCD display or the operating system, and get repaired by the nearest local service center. hope this help u.. further quries give me reply
Jul 25, 2009 | Samsung NC10-14GW Notebook
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
My BenQ FP757-12 monitor stopped working
I commend your courage in taking your monitor apart. I hope it was out of warranty when you did it; because it is out of warranty now.
I have no idea where to find the info you are looking for. Monitors are cheap now, though.
Dec 28, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
BenQ Q7t4 Monitor
Open it up and look for burned or some cold soldre joints. After resolder it should work.
Nov 14, 2008 | BenQ FP757 Monitor
BenQ FP757 monitor problem
the vga modul can't tobe start power "on",power regulator/switching normal condition. some of the semiconductors on board of the VGA modul ( transistor ) is Shock/dead. I need schema/diagram of this,please........
Oct 30, 2008 | BenQ FP757 Monitor
Computers & Internet Logo
208 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
