Question about Sansui DTV2760 27" TV
How to fix
The volume fluctuates constantly on my sansui 29"/68cm ctv-2911pf pure flat screen tv is there a volume regulator were would i get 1 or is their another solution
    Genius:
  • 1,694 Answers
Temporarily unsolder/remove vol up/down tactil switches on front of circuit board.They may be sending unwanted signals to the microprocessor. Does set work normally now? 2)Try removing batts from remote.3)PVAT! Pull chassis, Solder any/all bad connects esp. regulator pins.4)Send in to shop for diagnosis.
Posted on Oct 01, 2007
SOURCE:
How to fix sansui sv 4230 images
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 30, 2016 | Sansui Televison & Video
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Any one have the service manual of SANSUI MODEL CTV SFS21 ultra slim flat tv?help me
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 31, 2015 | Sansui Televison & Video
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
Pls send me sansui model-s2s21,21"ctv
i had sansui s2s21 model the problem is that the its screen display is very dim. kindly give the solution.
Feb 26, 2011 | Televison & Video
Spare parts for Sansui TV
Hello E.C. Wait
Your parts can be found simply on amazon, click here and take a look: Amazon com sansui tv parts. Wish you best of luck.
Donald
Nov 21, 2008 | Sansui HDLCD3200 TV
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Sansui DTV2760 27" TV Logo
161 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
