Question about Sony PlayStation 2 (PS2) Console
PS2 auto shut down when disc tray is close
I had no problem going into menue of the ps2. after i press the blue button, the disc tray ejected and i put a disc in and when the tray close, the ps2 shut off. even if i never put any disc inside, the ps2 shut off as well when the disc tray is close. need help...thanks ohya..i am using cables from ps1 so i don know if it will affect its performaces
    Problem Solver:
  • 10 Answers
Big mistake. never use ps1 cables on a ps2. i made the same mistake once.
Posted on Oct 07, 2007
  • graving Oct 07, 2007
    also, dont use ps1 controllers on ps2.
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
How to on ps2
  • Find a clear space, preferably out of direct sunlight, to set up your PlayStation 2.
  • Plug the AC adapter into the designated area on the back of the PlayStation 2 and then plug it into the wall socket.
  • Plug the RFU adapter or audio/video cords (depending on the model of your television) into the back of your PlayStation 2 and then into your television.
  • Plug your controller into the controller slot adjacent to the disc tray.
  • Plug your memory card into the memory card slot above the controller slot (see "How to Managage a PlayStation 2 Memory Card").
  • Turn your PlayStation 2 on using the on/off switch on the back of the PlayStation 2.
  • Press the eject button to open the disc tray. Insert a game disc and press the eject button again to close the tray and begin play.
  • Turn the PlayStation 2 off when done playing by either flipping the on/off switch or pressing the sleep button.
  • Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
    How to fix my playstation 2 that won t read grand theft auto san adreas
    Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
    You can also follow these steps to make your PS2 to play GTA San Andreas:
    1. Turn on your PS2 without inserting any disc.
    2. On menu screen go to [options] by pressing 'triangle' button.
    3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
    4. Then insert the game disc.
    5. Turn off your PS2.
    6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
    It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
    I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
    Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
    Disc tray wont open when eject button pressed on ps2
    The disc tray motor needs to be replaced. You can find one on ebay. A relatively easy fix. Good luck!
    Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
    Disc tray???
    Did you recently open the ps2/modify it?
    Found this which may help (and will void your warrenty):
    When you take the top cover off of the PS2, you can see where the Reset/Eject ribbon cable plugs into the system itself. Right next to and slightly below here are three wires with three tiny color-coded plug-ins attached. They are just pressed into place and have a tendency to work themselves out over time. And depending on which one came undone, the disc tray will either always want to stay closed or always want to stay open. Either way, the operation of the disc tray will be erratic and problematic.
    So it's a matter of using a pair of needle-nosed pliers to grasp and make sure that all three of these tiny plug-ins are fully inserted into the slots where they belong. Sometimes it's even necessary to very slightly lift the PS2 out of the bottom half of it's shell to gain better access to them. After they're all clearly in place, then it's a good idea to use the same needle-nosed pliers to make sure that the ribbon cable did not slightly pull out of place from where it is plugged in as well, or the Reset/Eject buttons will not work.
    After all this, you can put the PS2 back together and voila...you should be good to go!
    Sep 06, 2008 | Sony PlayStation 2 (PS2) Console
    Ps2
    you say it wont turn back on but it has power.
    is the light red ( stand by )
    or do you have green and blue lights
    Did it fall????
    try cleaning the disk and the lens
    you can also run the auto diagnosis..
    HERE'S HOW
    Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
    the above is a copyright of the PS2 user guide
    Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
    Playstaion 2
    can you go into the browser ?
    can you view your mem card?
    You can try the auto-diagnosis. heres how
    or try cleaning the lens and games
    Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
    Disk format
    1) Turn on machine
    2) Open Tray
    3) With tray still open hold the reset until the tray closes.
    4) Tap the reset once.
    if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
    Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
    Ps2
    hi check if the button is stuck you might need to open it becareful not to disconect anything and if you do first see were it goes ho it helps.
    Jun 22, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    190 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
