Question about BenQ FP737S-D 17" LCD Monitor
Monitor doesnt work
I had this monitor for about 2 and a half years.It is a BenQ FP737S-D 17" LCD. Well when i turn the monitor on, nothing appears its all black but the green LED light is on. Just about an hour ago it was working perfectly. Thanks
  • Andoru Oct 01, 2007
    @ SparkGap nope nothing all black.and yes the computer is giving off a signal because i can use my old monitor which is really old on the computer.
    @ Vishal51 Nope all black.
    Well i guess i have to get it check by a trained service engineer
  • vwrobb Nov 21, 2007
    my Benq same monitor is doing the same thing. Green light comes on but no screen. Totally black.??
Replace 3A PF### fuse on main board. (reason for the # is because I have put the monitor together and cant remember the component number) I could see with a torch the initial display on power up. The PCB has white writing on it to display what component should be on the board. All PFs on the board have wire links on them but one. It looks Iike a black cylinder, 7mm long, and 3mm diammeter. The green writing on it was "bel MS 3A". I would have found this fuse earlier, but the writing was facing down on the board. This fuse powers the circuit to the back lights. Please check continuity of fuse before replacing back lights, as a 10 cent fuse is cheeper than backlights.
Fuses WILL blow for no reason. I have replaced it with a 5A for testing, and everything checked out OK. Also the monitor powered up and has been running fine.
Posted on Jan 22, 2008
I'm no expert but is sounds like the backlight to me.
If you shine a light as someone mentioned above you should be able to see the "BENQ" logo faintly at startup. Try a few angle and If you can see it then I suggest you do this...
There are 2 assemblys that contain 2 small light strips that need to be replaced on both the top and bottom of the display.
Take the monitor apart and remove the display assemby. Place the assembly face down on a soft surface like a towel. Now you have to remove the back of the assemby that contains the curcuit boards. Open the little panel on the top right and carefull disconnect the ribbon connector by lifting the little plastic tab and gently pulling the ribbon out. Then remove the silver tape on the left side to reveal the power connections, unplug both and remove the bacl of the assembly from the screen. Now, as you look at the back of the screen, on the left side there will be 2 sets of wires near the top and bottom. The wires are taped to the assembly with a little pieces of black cloth tape, romove the tape and you'll see two tiny phillips head screws with litte arrows pointing at them. Remove the screws and gently tug on the wire until the backlight assemly slips out of the display chassis a little, then gently grasp the backlight assembly and carefully pull it out of the monitor. Take those parts to an lcd repair shop and ask for replacements or get them to replace the actual bulbs in the assemby. Re-assemble it and you should be good to go.
Hope that's a help.
Posted on Dec 03, 2007
  • 38 Answers
Switch off your monitor. Take out the VGA cable. Switch on your monitor. Does it display any message like "no video signal" and then go blank? If yes, replug your VGA cable it should work. If it still does not work, your VGA port of PC/cable of monitor has gone bad. If no, get your monitor checked by a trained service engineer, you cannot do anything about it. Still, TRY PRESSING THE BRIGHTNESS/CONTRAST BUTTONS ON THE PANEL. IT MIGHT HAVE BECOME TOO DARK ACCIDENTLY (OR BY DESIGN :-) )
Posted on Oct 01, 2007
  • 363 Answers
Shine a torch at the monitor screen from various angles, if you can see an image on the LCD then it could be the backlight or the PSU at fault. Do check that the computer is still giving a signal.
~Hello! My monitor dispays picture, but the picture isnt like it should be. Instead of normal colours it displays gray stripes, red is shown as yellow, windows 7 startup icon is in black box ect. When...
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Jul 15, 2011 | BenQ FP737S-D 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Benq 737s monitor black screen
BenQ LCDs are known for poor solder connections causing the inverter driver transistors to short.
Result is no backlight.
Monitor Mike
Jan 03, 2009 | BenQ FP737S-D 17" LCD Monitor
BenQ FP737-D 17 Monitor
Hey... what you need it a new backlight inverter, your old one it busted...
Sep 14, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP737-D 17" LCD monitor
IT almost sounds if the monitor itself is overheating? Have you tried shutting the monitor off for 15 or so minutes then turning it back on? It may also be a video card overheating issue. Make sure your PC and Monitor both have adequate ventilation.
IF this doesn't help the situation, try updating the video drivers as well.
Sep 11, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Nec LCD1720M
Replace the bulging caps:
C 701; 1000UF @ 35V
C 704; 1000UF @ 16V
other caps that may test weak and should be replaced are:
C727; 47UF @ 25V
C613; 10UF @ 50V
Jan 13, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq monitor flashes off and on
It has a large capactor inside that is leaky, needs changing. In powersupply.
Sep 14, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
186 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
