Question about BenQ Value V772 17" CRT Monitor
Benq v772 CRT show only Blue and Green color
Hi, what component(s) to replace when the Benq v772 CRT show only Blue and Green color (sometime only blue, i.e. Red and Green color missing) any idea? thks
  • gtxgtx Oct 02, 2007
    ok, i'll try to check the cable first.
  • 38 Answers
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Posted on Oct 01, 2007
  • mmop
    mmop Nov 30, 2013
    ok my cable is checked
  • mmop
    mmop Nov 30, 2013
    after then what should I do
Hi my audiovox fpe2705 needs red color in shows only in green an blue thank you
remove back cover then check the CRT tube if there is color red cathode how?by using a wire or test prove connected in ground in your TV very quick if red screen flashes your CRT is good then check your CRT board socket find the driver transistor of red cathode then check it if shorted replace thank you
Mar 05, 2011 | Televison & Video
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
My tv only shows the blue and green colors. I opened up the back and the red lens is not on????? What do I do?????
Check if the menu display shows the same. If the same, then check CRT, CRT board, G2 voltage for around 200V. If menu display ok, check red component cable. :)
Dec 29, 2009 | Sony KP-61V90 61" Rear Projection...
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
My Benq monitor model V772 turn yellowish occasionally
To solve the problem on my monitor i did a thorough inspection on the pcb which is fixed on the tube and i solder components which looked suspicious for dry joints.
Dec 27, 2008 | BenQ Value V772 17" CRT Monitor
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Color display issues with BenQ FP757 monitor
Go to menu and try Recall all.
Also possible that panel is defective.
Samir
Oct 01, 2007 | BenQ FP757 Monitor
BenQ Value V772 17" CRT Monitor Logo
202 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
