Question about Linksys 5-Port Ethernet Switch (SD205-UK)
Cannot connect hi there, my problem is that i dunno how to connect the Linksys Phone adapter with 2 ports for Voice-over-IP to Linksys 5-Port 10/100 Switch thru my PC and Phone.. please give me an simple instructions or a simple diagram ..thankyou
Product Key # on side of Asus CM 5570 model computer...if you go to control panel on computer/system it shows Product ID number as different...states about "change it". Do we click and then put in Product Key # on side of computer. Confused.
Posted on Sep 17, 2009
  • 49 Answers
What is the model number? you can go to this site
www.linksys.com/download
or www.linksys.com only and search for the product. the model number is underneath your device.
Posted on Oct 25, 2007
SOURCE:
No dial tone
Hi Richard,
May be your new Router is blocking the ports used by your IP Phone by default. Check with your phone service provider for Voice Port (Mostly SIP or H.323 or SCCP) and open that port in your router.
HTH
-Karthik.
Oct 18, 2012 | Linksys SPA942 IP Phone
Ican call out but calls
Reset the phone to the factory settings
Jun 09, 2008 | Lands Phones
IP ADDRESS OF VOIP PHONE ADAPTER 2 PORT PAP2NA
doanload colosoft netscan, when you have it plugged into the network, run netscan on a computer thats on the same network....that'll find it for you, if that doesnt work give me the specs on the phone and ill check the manuels..
Jan 22, 2009 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
I need help with ipod touch how do i get wi-fi
just set up the router on another computer then u can use ur tutch
Jan 16, 2009 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Internet connection
This is a firmware problem of the router so better update the firmware of the router to resolve this concern.........You can download the firmware from Linksys web site.......
Jun 09, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Firmware Upgrade?
i have pap2 phone adapter it has some problem. i says This is the voice massage i have got it from my phone.
Connected in the incorrect phone port. Please try other port. If you believe
your correct port. Please log on to your web account to check your states of
your service O108.
This is the voice massage i have got it when you pickup the phone
immediately the voice massage will comes.
please help me anyone
Thanks
partheeban
Jun 08, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Pls. help
When dealing with a router there are multiple IP address scenarios, on the internet service provider's (ISP) side you can have either a static or dynamic IP address. I believe most routers by default are set to accept a dynamic IP address from the ISP. Where the ISP permits the router can also assign IP addresses to each device that attaches to it allowing a single ISP connection to be shared by multiple computers. This is also generally the default for routers purchased for home use and the wireless adapters also accept the dynamic IP assignment from the Router. With the logical discussion out of the way I believe you wish to discuss the physical connections to be established. Again this is a generic discussion not knowing your specific environment. port types - I will refer to phone ports (technically RJ-11 either two or 4 wires (these cables plug snugly into phone jacks and modem connectors) and ethernet ports (technically RJ-45 which are 8 wires and to big to fit in phone and modem ports) First you have a connection provided by the ISP for DSL this is your phone line where filters are attached to your voice phones and an unfiltered phone connection goes into the DSL modem's phone port often with an ethernet port. If you have cable generally the cable company provides a connection to a cable modem which has an ethernet or other port to connect to your system. The ethernet port generally connects to the wan port (generally separate) of your wrt54g router with an ethernet cable. Computers can be attached to the wrt54g router using the 4 ethernet ports in a group provided they have an ethernet port too. Wireless cards connect to the wrt54g router through radio waves and with antennas on the router and often internal to the wireless adapter (often embedded in a notebook computer today). These details are enclosed with your ISP's instructions and the Linksys router instructions often with pictures to help the explanation.
see
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1149562300349
if you do not have the user manual.
Nov 30, 2007 | ASUS AAM6010EV Router
Linksys 5-Port Ethernet Switch (SD205-UK) Logo
174 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
