Question about GE 74801 Clock Radio
Setting the time
How do I set the time on this thing!
  • 2 more comments
  • blackheart79 Oct 03, 2007
    Anyone that has a problem with this radio be patient because once it starts working in the way it should it is an awesome clock radio!
  • jaquan Nov 19, 2007
    IT is very hard to set the time where i press the the start button nothing flash.
  • Anonymous Jan 30, 2008
    I can't get the cd to play. We used it three times and it worked fine. But can't get it to play again. I don't have a manual. It was givin to my son. Does anyone have a solution? And were can I buy it new?
    Sandi
  • reid_jay Feb 13, 2008
    Cannot set the time
This info is in the pdf manual (pg 5) posted on the FixYa page for this problem (about middle of the page). I can't paste in the graphic but this is what the page says:
Setting time: (graphic is of the top of the radio with the buttons)
1. Press the SET button, the “ : ” will flash on the display .
2. Press REV (L arrow) or FWD (R arrow) to set the time.
3. AM or PM icon will show beside the time.
Tip: No icon will be flashing if all selectors are set. If you see any icon flashing on the display, press the SET button repeatedly to confirm everything is set correctly.
Posted on Nov 06, 2007
What does it mean if it starts beeping uncontrolably? Is this normal? If so, then why is it not affected by the volume control?
Also; I cannot figure out how to set it to AM or PM.
Who makes a clock/radio this hard? It didn't even come with a feasable user's manual.
Posted on Feb 05, 2008
PC suite certificate is not valid or wrong date and time setting. how to solve it? Nokia N70.
Please check and adjust your computer's date and time. Also, check your phone's time and date setting, because if they sync between computer and phone it will do the same thing
Jul 31, 2011 | Nokia N70 Cellular Phone
My clutch on my 18v drill is on all the time even when at the maximun setting
If that thing is still slipping when it is on the drill setting you have big problems...
There should be a setting beyond the clutch setting that has a drill bit there...it should lockup there and not slip at all...
if it is still slipping then you can find parts for many drills at ereplacementparts.com
heatman101
Feb 06, 2011 | Garden
My Dell inspiron 1525 frequently has a sort of freeze up when no keys will work .hovering over things causes them to highlight and I need to hit the escape key many times to unfreeze it.
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 06, 2010 | Dell Inspiron 1525 Laptop
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
I'm having trouble setting the timing belt back to its setting.Can you give me more less an idea of how it has to be done? Thanks,Maritza
Very sensitive set up.There are special tools needed that make things much easier on the 3.0 liter.If you miss time it you can bend valves & due major damage to valves & heads.Best advise I can give from afar is get yourself a good haynes manual.They are not bad if you have done a few of them & have the special tools.hope this helps
May 20, 2009 | 2003 Saturn L-Series
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
How to get from military time to standared time no instructions manuel
Hold "Set"
use "mode" to browse
when you get to time setting the 24h/12h setting should be first thing you can do. press "St/Sp" button when you see the "24h" icon flash it should switch to "12h"
Press "Set" You are done!
Jan 06, 2009 | Columbia All Sport Digital watch
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
Toaster Setting
There is a mini adjustable potentiometer facing the left side on the circuit board. Turning it counter clockwise to your taste.
Sep 27, 2007 | Oster 6243 2-Slice Toaster
GE 74801 Clock Radio Logo
304 people viewed this question
Top GE Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Racki123
Level 1 Expert
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
